Watchdog timer doesn't turn off 18F4620 PIC
ac34856
PostPosted: Tue Feb 16, 2010 9:44 am     Reply with quote
I'm having trouble getting the WDT to turn off. The following code
runs but the line setup_wdt(WDT_OFF) doesnt work - in other words the WDT still runs. I would also like to dynamically change the Watchdog timeout prescaler value other than in the fuses.
Compiler 4.057
Any comments appreciated.
#include    <18F4620.h>
#device       PASS_STRINGS=IN_RAM
#fuses       HS         // High speed oscillator
#fuses      WDT         // Watchdog timer enabled
#fuses       WDT1024      // Watchdog timer prescaler
#fuses       NOPROTECT
#fuses      BROWNOUT   // Has protection for recovery from low Vcc
#fuses      PUT         // Has power up timer
#fuses      NOLVP      // No Low voltage programming
#fuses      MCLR
#fuses      NODEBUG
#use       DELAY(clock = 20000000, RESTART_WDT)
#use       RS232(baud=115200, XMIT=PIN_C6, RCV=PIN_C7, ERRORS, STREAM=USB, RESTART_WDT)
TYPEDEF   unsigned int16 UINT16;
UINT16   reason;
static UINT16 count;
void    main(void)
reason = restart_cause();
switch(reason)
   {   case WDT_TIMEOUT:
      {   fprintf(USB, "\r\n Watchdog timed out - CPU Reset ! ");
      case NORMAL_POWER_UP:
      {   fprintf(USB, "\r\n  CPU Started normally !");
      default:
         fprintf(USB, "\r\n Miscellaneous Restart (%04Xh)", reason);
setup_wdt(WDT_OFF);      // !!! Why doesnt this line work ??
   ++count;
      fprintf(USB, "\r\n A - Sleeping until WDT (Count: %Lu)", count);
   delay_ms(10);
   while(1);         // Stop here waiting for WDT to test .. ..
      //   sleep();             // Go to sleep and wait for WDT to wake-up
      fprintf(USB, "\r\n Woken up !");
   //   restart_wdt();
      delay_ms(300);
PostPosted: Tue Feb 16, 2010 11:20 am     Reply with quote
Read the data sheet.....
Critical line:
"PIC18F2525/2620/4525/
4620 devices have a Watchdog Timer, which is either
permanently enabled via the configuration bits or
software controlled (if configured as disabled)."
You can only _software control_the watchdog timer, if it is _disabled_ in the fuses. If you set it to enabled in the fuses, it will _always_ run.
If you want to software control the 'effective' watchdog time, then have a timer interrupt, at a slightly higher frequency than your programmed watchdog time. Have an internal global variable called (say) wdog, then in the timer interrupt have:
    if (wdog) {
        --wdog;
        restart_wdt();
You can then in your code at any point set 'wdog' to a value, and have this many beats of the timer interrupt, plus the hardware watchdog time, till the watchdog will trigger.
ac34856
PostPosted: Wed Feb 17, 2010 10:37 am     Reply with quote
Thanks .. that is an excellent piece of information !
