icd u40 breakpoints
patrick
icd u40 breakpoints
PostPosted: Thu Oct 09, 2008 5:07 pm     Reply with quote
Hello
how many breakpoints are possible with the ICD U40 debugger?
Can i stop debugging on a point and then run it again?
PostPosted: Tue Oct 21, 2008 5:42 pm     Reply with quote
CCS doesn't post the ICD-U40 manual online. But, it has to be similar
to the Microchip ICD2. Here's the manual for the ICD2:
http://ww1.microchip.com/downloads/en/DeviceDoc/51331c.pdf
On page 35 (page 41 in the Acrobat reader), it says:
2.7.2.2 BREAKPOINTS
Note: For most devices, only one breakpoint will be set
(active) at a time, although you may specify more
than one breakpoint in the breakpoint dialog (i.e., one
breakpoint will be active and the others will be
inactive).
