PWM
eng/ IBRAHIM
PWM
PostPosted: Tue Aug 14, 2007 7:04 am     Reply with quote
How i generating a PWM with 100hz,50% duty using 16F877
PostPosted: Tue Aug 14, 2007 11:57 am     Reply with quote
Learn how to use the forum's search page:
http://www.ccsinfo.com/forum/search.php
Put in these words in the search box:
PWM 100Hz
Also choose this setting:
x Search for all terms
Then do the search, and you will get a list of 18 matches.
The 4th one in the list is sample code in the Code Library
for PWM at 100 Hz.
Steve H
PostPosted: Tue Aug 14, 2007 8:11 pm     Reply with quote
As PCM Programmer suggests search and you will find a nifty exe that makes code for you - also you can check this web page out,
micro-examples.com/public/microex-navig/doc/097-pwm-calculator.html
HTH - Steve H.
