digicomk
				| Single Pin DTMF Tone Generation |
				 Posted: Thu Aug 30, 2007 11:15 am     |
				You can use any pin, just connect a 10K resistor series and a 0.1uF cap to ground. Now the news...
The good news is you can generate all 16 standard DTMF tones, you can use any PIC, you can change the pin and freq. if you change the times acordingly.
The bad news is the code is assembly PARALLAX version. Those of you having TECH-TOOLS tools can run the code right away.Others can go to www.tech-tools.com and get information about how to translate it.
Maybe somebody make a translation to native MICROCHIP and post it here. I can't promise to do it for a cople of month. Another issue, due to the forum's editor or my lack of skills with it, I'm not able to copy the code with the original labels tabs and spaces. You should figure out and make your own typing. Sooorry.
Here is the code
;         DTMF
     include 'c:\pictools\16f873a.inc'
        fuses _hs_osc&_wdt_off
        fuses _cp_all&_lvp_off
;      org   20h
al              =       20h
ah              =       21h
bl              =       22h
bh              =       23h
cl              =       24h
ch              =       25h
dl              =       26h
dh              =       27h
bitmask         =       28h
tristate        =       29h
outstate        =       2ah
temp            =       2ch
pwm             =       2dh
number_ptr      =       2eh
temp2           =       2fh
lookup_number   jmp     pc+w
;               retw    12,13,80h
;               retw    2,2,2,2,2,2,2,2,2,2,2,2,2,80h
;               retw    9,9,0,1,9,1,6,7,2,5,1,7,8,9,80h
;               retw    9,9,0,1,9,1,6,7,2,1,8,2,1,7,80h
;               retw    5,6,6,3,2,3,1,80h
;;              retw    5,8,3,9,80h
;               retw    1,4,7,10,2,5,8,0,3,6,9,11,12,13,14,15,80h
;               retw    9,3,1,6,6,1,8,8,5,80h
      retw    6,5,3,7,4,2,4,80h
;               retw    8,8,9,8,4,9,80h
;               retw    5,6,3,2,5,6,8,80h
;               retw    0,1,1,3,5,8,0,5,6,6,3,2,3,1,11,80h
;               retw    7,2,1,8,2,1,7,80h
;               retw    9,7,2,0,9,7,0,0ffh
; Frequency formula:     c = Freq/(4000000/4/66/8/256) = Freq/7.40
;             constant --|    |       |    | |  |  |
;     target frequency ------ |       |    | |  |  |
;  cpu clock frequency ---------------|    | |  |  |
; 4:1 instruction rate --------------------| |  |  |
;          cycles/loop ----------------------|  |  |
;     samples/sinewave -------------------------|  |
;           c/256 rate ----------------------------|
r1              =       94      ;697 Hz
r2              =       104     ;770 Hz
r3              =       115     ;852 Hz
r4              =       127     ;941 Hz
c1              =       163     ;1209 Hz
c2              =       181     ;1336 Hz
c3              =       200     ;1477 Hz
c4              =       221     ;1632 Hz
lookup_freqs    jmp     pc+w                    ;lookup row and col frequencies
      retw    r4,c2   ;0
      retw    r1,c1   ;1
      retw    r1,c2   ;2
      retw    r1,c3   ;3
      retw    r2,c1   ;4
      retw    r2,c2   ;5
      retw    r2,c3   ;6
      retw    r3,c1   ;7
      retw    r3,c2   ;8
      retw    r3,c3   ;9
      retw    r4,c1   ;*
      retw    r4,c3   ;#
      retw    r1,c4   ;A
      retw    r2,c4   ;B
      retw    r3,c4   ;C
      retw    r4,c4   ;D
lookup_sine     jmp     pc+w
      retw    3,5,6,5,3,1,0,1
lookup_pwm      jmp     pc+w
      retw    000000b
      retw    100000b
      retw    010000b
      retw    100100b
      retw    010100b
      retw    101010b
      retw    011010b
      retw    110110b
      retw    011101b
      retw    111011b
      retw    011111b
      retw    111111b
      retw    111111b
start      clr     intcon
      mov     !ra,#30h
      mov     !rb,#04
      mov     !rc,#0ffh
      clr     ra
      clr     rb
      clr     rc
      setb   rp0
      mov   adcon1,#07
      clrb   rp0
      mov     !option,#44h
                mov     bitmask,#00000100b
      mov     tristate,#00000000b
      mov     outstate,#00000000b
      mov     !rb,tristate
wait            jb      ra.1,wait
      clr     number_ptr
:loop           mov     w,number_ptr
      inc     number_ptr
      call    lookup_number
      mov     dh,w
      jb      dh.7,:done
      clc
      rl      dh
      mov     w,dh
      call    lookup_freqs
      mov     al,w
      mov     w,++dh
      call    lookup_freqs
      mov     ah,w
      call    dtmf_output
      mov     dh,#035h
:slow           djnz    dl,:slow
      djnz    dh,:slow
      jmp     :loop
:done           jnb     ra.1,:done
      jmp     start
; DTMF output
; in:   al=tone1, ah=tone2
; uses: bl,bh,cl,ch,dl,dh
dtmf_output     mov     dh,#230
      clr     bl
      clr     bh
      clr     fsr
      clr     cl
      clr     ch
:loop           add     bl,al           ;2      ;update tone1
      snc                     ;1
      inc     cl              ;1
      clrb    cl.3            ;1
      mov     w,outstate      ;1      ;output bit3
      snb     pwm.3           ;1
      or      w,bitmask       ;1
      mov     rb,w            ;1
      add     bh,ah           ;2      ;update tone2
      snc                     ;1
      inc     ch              ;1
      clrb    ch.3            ;1
      inc     fsr             ;1      ;inc time
      snz                     ;1
      inc     dh              ;1
      mov     w,outstate      ;1      ;output bit2
      snb     pwm.2           ;1
      or      w,bitmask       ;1
      mov     rb,w            ;1
      mov     w,cl            ;1      ;lookup sine1
      call    lookup_sine     ;6
      mov     temp,w          ;1
      mov     w,outstate      ;1      ;output bit1
      snb     pwm.1           ;1
      or      w,bitmask       ;1
      mov     rb,w            ;1
      mov     w,ch            ;1      ;lookup sine2
      call    lookup_sine     ;6
      add     temp,w          ;1
      mov     w,outstate      ;1      ;output bit0
      snb     pwm.0           ;1
      or      w,bitmask       ;1
      mov     rb,w            ;1
      mov     w,temp          ;1      ;lookup pwm
      call    lookup_pwm      ;6
      mov     pwm,w           ;1
      mov     w,outstate      ;1      ;output bit5 (1/2 bit)
      snb     pwm.5           ;1
      or      w,bitmask       ;1
      mov     rb,w            ;1
      jmp     $+1             ;2
      mov     w,outstate      ;1      ;output bit4
      snb     pwm.4           ;1
      or      w,bitmask       ;1
      mov     rb,w            ;1
      movsz   w,++dh          ;1      ;loop if not done
      jmp     :loop           ;2      ;66us/loop
      mov     rb,outstate     ;call   set_low
      ret
