Hi!
I've just started using PIC16F877A and I've loaded a bootloader on top of flash. Bootloader writes reset vector in order to be the first program executed. I compile my program with MPLAB(CCS) and it puts reset vector to the main program. I've tried putting #ORG ox0000,0x0004 {} but it doesn't work.
I should too write my first program's direction on 0x1F2E.
Original Post ID: 12895
R.J.Hamlett Guest
Re: Reset vector where I want it
Posted: Thu Mar 20, 2003 3:45 pm
:=Hi!
:= I've just started using PIC16F877A and I've loaded a bootloader on top of flash. Bootloader writes reset vector in order to be the first program executed. I compile my program with MPLAB(CCS) and it puts reset vector to the main program. I've tried putting #ORG ox0000,0x0004 {} but it doesn't work.
:= I should too write my first program's direction on 0x1F2E.
Have a look at this thread:
<a href="http://www.pic-c.com/forum/general/posts/10731.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/10731.html</a>
The #build (undocumented) directive, allows the reset to be relocated as you require.
Original Post ID: 12896
