problem with PCWH V4.040 and the ICD-U40 2.14 rev #99
inservi
PostPosted: Thu Jun 07, 2007 2:33 am     Reply with quote
I work with XP pro sp2.
With version 4.039, ICD-U40 worked perfectly as well with “PCWH” than with “ICD program interfaces”.
When I installed PCWH V4.040, the first time that I test “ICD interfaces program” that worked well.
After that, I charged PCWH V4.040, launched a compilation, and then, I launched ICD (from the menu of PCWH ide).
Since this moment, the USB connection is stop to worked ( when launch ICD, the dialog box for serial connection appear).
It is then the same problem from “ICD program interfaces” and from PCWH ide.
The only manner that I found to fix the problem is to reinstall PCWH V4.039 and the driver of usb ICD-U40. I make with this test 3 times.
Can you explain how to use PCWH v4.040 and the ICD-U40 ?
Thank-you.
dro.
in médio virtus
horkesley
PostPosted: Fri Jun 08, 2007 8:40 am     Reply with quote
I to have problems with the USB. I receive a message saying 'no response from target' there is nothing wrong with the target, the USB has crashed.
I used to use an old ICD1 and this worked better than the ICD-U40, albeit a little slower. But this does not work with 4.040.
I am also trying to use a Ramtex driver for a LCD display and seem to have a compatibility problem.
CCS say they have no experience/knowledge of Ramtex, Ramtex say they have had discussuions with CCS regarding compatibility.
Meanwhile, my project is falling behind.
Any comment anyone.
HiTech?
Horkesley Electronics Limited
inservi
PostPosted: Fri Jun 08, 2007 11:51 pm     Reply with quote
Yes, for summarize, the USB driver is corrupted after the first usage PCWH 4.040.
CCS must absolutely improve its debugging process !
dro
in médio virtus
dini
ICD software issue
PostPosted: Wed Jun 20, 2007 1:45 pm     Reply with quote
Try downloading the latest ICDsoftware(V2.79). Also email support@ccsinfo.com to report issues as this forum is not regularly monitored.
inservi
PostPosted: Fri Jun 22, 2007 12:40 am     Reply with quote
Thank-you dini. I will try that.
Before encumbering the CCS support (which is obviously already very overloaded), I prefer to put the question in this forum because I do not know if it is a bug or an error from me. Also note that I subjected this problem to the CCS support and that I did not receive any answer.
Best regards,
dro.
in médio virtus
