arunb1 Guest
Unable to login, username correct, received new password.. |
Posted: Thu Apr 19, 2007 9:34 pm |
I suddenly found this morning that I was not logged in to this forum, I used my password and username but still could not login..
I then used 'forgot my password' link to get a new one, but even with the new password I could not login to the forum, kindly advise what I should do ....
thanks
arunb |
Posted: Thu Apr 19, 2007 9:56 pm |
I had that happen to me once or twice. A technician at my isp told me
that it was a problem with the router at Cox.net. At the time, CCS
went through that router. The tech said that it was dropping packets,
and it took awhile to convince Cox.net that they actually had a problem.
The effect for me was that I could usually view the forum, but I couldn't
log in. In fact, most of the time, I had to use the direct IP address of
the forum to even be able to view the forum. I got the IP from
http://www.dnsstuff.com
My guess is that your problem will probably go away in a day, or maybe
a few days. |
