Constructive criticism to CCS ICDs
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Wed Apr 04, 2007 1:51 am     Reply with quote
During the last week I was caught into a loop of backwards incompatibility issues between PIC uC, ICD hardware and ICD firmware.
Simultaneously and independently, my partner had nearly fried his laptop, because high voltage leaked to the ICD and then into the laptop’s USB. That caused the USB hub to shut off, only power-cycling the laptop made the hub to turn back on. Only the ICD blew up, but it could have ended up much worse.
Here are some suggestions that will simplify everyone’s lifes
- Lack of descriptive documentation. CCS will not lose anything, if it publishes the schematic. In fact, it will save on technical support. All of CCS’s proprietary knowledge is in the ICD firmware. There is a half-dozen ICD clone designs freely available anyways.
- There's no galvanicaly isolated version. It’s easy to isolate serial lines between FTDI232 and the PIC, although the isolated ICD will require a larger enclosure. The cost of additional isolation parts can be as low as $15, including the optional isolated DC/DC. There are a lot of people, who use high voltages (for motors, for example).
Does anyone else have suggestions? Is CCS working on any of this?
MikeW
PostPosted: Fri Apr 06, 2007 9:55 pm     Reply with quote
I agree about releasing the schematics. I just blew my ICD-U40 up, and now it just sits there.
Since I am in Europe, it just isnt worth trying to get it fixed.
I prefer the ICD-U40 over the microchip one, mainly because I use the CCS debugging environment.
Galvanic isolation would be good, but I accept that the ICD-U40 is low cost, and so raising the cost by 30-40% wouldnt be a good idea.
I use the Analog devices digital isolators,u/adM1201 etc, and that may be a cheaper route for CCS.
Mike
mdemuth
PostPosted: Tue Apr 17, 2007 1:57 pm     Reply with quote
I am using two tools:
1. olimex ICD-clone.:
All critical parts (74HC146) are mounted.
If you blow them, you can easily change them.
2. USBurn
Simple, efficient and small programmer.
Perfect if you just want to program and nothing more.
kender
PostPosted: Tue Apr 17, 2007 2:00 pm     Reply with quote
Can you use it with the debug features of the CCS compiler (break points, watch, monitor etc) ?
Read the label, before opening a can of worms.
mdemuth
PostPosted: Tue Apr 17, 2007 2:08 pm     Reply with quote
DESCRIPTION: Low cost development tool providing real time emulation for all PICs with build-in ICD feature. Can operate through RS232 or USB, it's completely replacement of MICROCHIP's MPLAB-ICD2. More information you can find on Microchip's web site.
HARDWARE: PIC ICSP connector (top view)
SOFTWARE: MPLAB-IDE
FAQ:
Q: What's the difference between PIC-ICD2 and MPLAB-ICD2?
A: There is no functional difference between them and PIC-ICD2 is 100% compatible to MPLAB-ICD2. The only difference is the ICSP connector - Microchip uses RJ45 phone jack connector, we use 0.1" step connector
For further information:
http://www.olimex.com/dev/index.html
Neutone
Re: Constructive criticism to CCS ICDs
PostPosted: Wed Apr 18, 2007 11:09 am     Reply with quote
Reminds me of when I was trying to debug a PID routine for motor control.
B&B make a USB isolator.
