12F683 PIN_A3
mmprestine
12F683 PIN_A3
PostPosted: Thu Oct 18, 2007 9:53 am     Reply with quote
I am looking to use PIN_A3 on a 12f683 as an output and seem to be missing somthing in the setup. When I compile the following code and run it in the MPLAB sim it never toggles. I have searched the forum and tried serval things with the register setup but to no prevail the same thing in the end. Any thoughts?
compiler version 3.249
#include <12F683.h>
#device adc=8
#FUSES NOWDT      //No Watch Dog Timer
#FUSES NOCPD      //No EE protection
#FUSES NOPROTECT   //Code not protected from reading
#FUSES NOMCLR      //Master Clear pin used for I/O
#FUSES NOPUT      //No Power Up Timer
#FUSES INTRC_IO      //Internal RC Osc, no CLKOUT
#FUSES NOBROWNOUT   //No brownout reset
#FUSES NOIESO      //Internal External Switch Over mode disabled
#FUSES NOFCMEN   //Fail-safe clock monitor disabled
#use delay(clock=8000000)
   setup_adc(ADC_OFF);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   setup_oscillator(OSC_8MHZ);
   SET_TRIS_A(0b00000000);
   While(true)
      output_high(PIN_A0);
      output_high(PIN_A1);
      output_high(PIN_A2);
      output_high(PIN_A3);
      output_high(PIN_A4);
      output_high(PIN_A5);
      output_low(PIN_A0);
      output_low(PIN_A1);
      output_low(PIN_A2);
      output_low(PIN_A3);
      output_low(PIN_A4);
      output_low(PIN_A5);
mmprestine
PostPosted: Thu Oct 18, 2007 10:39 am     Reply with quote
Shocked Guess I should have read the data sheet a bit more closely. GPIO3 is only configurable as a general purpose input or as a Master Clear with weak pull-up.
