| gianni_pancrazi
				| AD7691 Driver |
				|  Posted: Wed Feb 21, 2007 10:40 am |   |
				| At the end I managed to realize it...   I'm using a 4 wire bus, with CS.
  	  | Code: |  	  | #include<Header.h>
 #device *=16
 #use delay(clock=16000000)
 #define SDI    PIN_B4
 #define SDO  PIN_C5      // the pin description is PIC oriented
 #define SCKL PIN_C3
 #define CNV  PIN_A4
 #define LED  PIN_B2
 int32 data=0;
 int i;
 unsigned long cnt=0;
 output_high(SDO);
 output_high(CNV);         /* Starting conversion */
 output_low(SDO);
 delay_us(15);
 /* Conversion Ended */
 for(i=19;i>0;--i)
 //   for(i=32;i>13;--i)
 output_low(SCKL);
 output_high(SCKL);
 shift_left(&data,3,input(SDI));  /* maybe 1 instead of 3???*/
 //   bit_set(data, i)
 //   this function is too slow to be used in the application...
 output_high(SDO);
 output_low(CNV);
 cnt ++;
 if (cnt==10000)
 //      printf("\r the acquired value is: %x", data);
 printf("%x", data);
 data=0;
 output_toggle(LED);      /* Blinking LED for debugging*/
 cnt=0;
 } // main() END
 I will happy if anybody of u has comments/suggestions...
