| Humberto
				| 74597 Driver |
				|  Posted: Thu Jan 25, 2007 4:55 pm |   |
				|  	  | Code: |  	  | /////////////////////////////////////////////////////////////////////////
 ////                             74597.C                             ////
 ////  Driver for 74**597  8 Bit Shift Register with input latches    ////
 ////  void init_597( )                                               ////
 ////                    Must be called once in the initializacion.   ////
 ////  int get_597_In( )                                              ////
 ////                    Return the 8 parallel input data.            ////
 ////  Autor: Humberto                                                ////
 // 74**597  8 Bit Shift Register with input latches
 // PIN nomenclature used in the code is as follows:
 //       PIN OUT
 //       ___  ___
 //   Q1-|        |- Vcc                   < = INPUTS
 //   Q2-|        |- Q0
 //   Q3-|       <|- PIN14 SER
 //   Q4-|       <|- PIN13 SLOAD
 //   Q5-|       <|- PIN12 RCK
 //   Q6-|       <|- PIN11 SCK
 //   Q7-|       <|- PIN10 SCLR
 //  Gnd-|       >|- PIN9  Qout
 //      |________|
 void init_597()
 output_low(SCLR);      // activate reset
 delay_us(10);          //
 output_low(SCK);       // idle level
 output_low(RCK);       // idle level
 output_high(SLOAD);    // select serial
 output_high(SCLR);     // deactivate reset
 int get_597_In()
 int8 i, value;
 output_high(RCK);       // Data loaded to input latches
 delay_us(10);
 output_low(RCK);        // Freeze inputs
 delay_us(10);
 output_low(SLOAD);      // Data transfer from input latch to
 delay_us(10);           // shift registers
 output_high(SLOAD);
 for(i=1; i<=8; i++)     // Clock-in while collecting bits...
 shift_left(&value,1,input(Qout));
 output_high(SCK);   // going up clock pulse
 delay_us(10);
 output_low(SCK);    // recover idle level
 return(value);
 Humberto
