Neutone
Flashing LED's beyond on and off |
Posted: Fri Dec 08, 2006 3:29 pm |
It's probably one of the first things most people learn to do with code on an embedded processor. A lot of circuits don't have much of a way to display information other than a single LED. A single LED can have 5 completely distinct visual states.
Off
Flash 1/2 second on/off
Strobe 1/8 second on/off
Flash/Strobe
On
I like to have the LED off only when the circuit has no power. That means I only need to control 4 states when power is on. I usually have 2 bits that carry some kind of information. Assume you want to show when an alarm occurs and when some process is happening.
Int16 LED_period=0;
Int1 LED_Alarm=0;
Int1 LED_Process=0;
Void Service_LED(Void)
{ if(LED_period)
{ LED_period--;
Else
{ LED_period=4000;
Status_LED=(bit_test(LED_period,8) || !LED_Alarm)
&& (bit_test(LED_period,6) || !LED_Process);
The service routine needs to be called every mS as written. The rate can be changed by changing the bits tested in the bit_test. The alarm and process bits are modified elsewhere. This compiles to a very small size and has very low execution time as well. This can be reduced if you already have a mSecond variable that can be used in the place of LED_period. |
Storic
Joined: 03 Dec 2005 Posts: 182 Location: Australia SA
Posted: Sat Dec 09, 2006 4:07 pm |
With the Status_LED,I am not sure of the bit
is it a variable or the output bit (led)
below I assigned Status_LED as a bit 2 of Port B
Code: | #byte State_L = 0xF81 // PORT B; PORT A = 0xF80
#bit Status_LED = State_L.2
my question is How did you assigned Status_LED, I will get to try the above code within the next few weeks.
Andrew _________________ What has been learnt if you make the same mistake?  |
Neutone
Posted: Sun Dec 10, 2006 12:51 am |
Did you set the pin as an output?
This example code flashes an LED that lights up when the output on pin B5 goes low. I ran this on the CCS developers kit for PIC18F452.
Code: | #include <18F452.h>
#fuses NOWDT,WDT128,HS, NOOSCSEN, BROWNOUT, BORV20, PUT, STVREN, NOLVP
#byte Port_B = 0xF8A
#bit Status_LED = Port_B.5
Int16 mS_Counter;
Int16 Second_Counter;
Int1 LED_Alarm;
Int1 LED_Process;
{ Status_LED=!((bit_test(mS_Counter,8) || !LED_Alarm)
&& (bit_test(mS_Counter,5) || !LED_Process));
#int_TIMER2
TIMER2_isr()
{ mS_Counter++;
if(mS_Counter>999)
{ mS_Counter=0;
Second_Counter++;
{ setup_timer_2(T2_DIV_BY_4,249,5);
SET_TRIS_B(0b11001111);
{ Service_LED();
LED_Alarm=bit_test(Second_Counter,3); // For lack of a real alarm just turn on and off
LED_Process=bit_test(Second_Counter,4); // For lack of a real process just turn on and off
