Ivar Boer Guest
| ICP Programming goes wrong when using the supply of ICD2 |
Posted: Mon Mar 17, 2003 7:35 am |
Hello programmers,
In my application iam using a PIC16F877A processor with an ICD2 (and MPLAB IDE 6.13) for in circuit programming. USB is used for connection between PC and ICD2. An external adapter is connected to the ICD2 (someone said this is neccessary to source enough current when using USB)
When iam programming my processor using the supply of the ICD2 (adjusted in MPLAB) my application does strange things (like an instable fan PI-controlling)
When iam programming my processor using the supply of my PCB my application works properly.
Please! contact me if someone knows about this problem.
I have also discovered an EEPROM error on address 0x63 of my EEPROM (I programm 0xFF and 0x77 is read when verifying). I don't know if this has something to do with it.
Thanks to you all.
Ivar
___________________________
Original Post ID: 12763 |
John Yaron Guest
| Re: ICP Programming goes wrong when using the supply of ICD2 |
Posted: Mon Mar 17, 2003 10:54 pm |
:=Hello programmers,
:=In my application iam using a PIC16F877A processor with an ICD2 (and MPLAB IDE 6.13) for in circuit programming. USB is used for connection between PC and ICD2. An external adapter is connected to the ICD2 (someone said this is neccessary to source enough current when using USB)
:=When iam programming my processor using the supply of the ICD2 (adjusted in MPLAB) my application does strange things (like an instable fan PI-controlling)
:=When iam programming my processor using the supply of my PCB my application works properly.
:=Please! contact me if someone knows about this problem.
:=I have also discovered an EEPROM error on address 0x63 of my EEPROM (I programm 0xFF and 0x77 is read when verifying). I don't know if this has something to do with it.
:=Thanks to you all.
:=Ivar
I've had trouble with having my target digital ground
connected to chassis ground. If I maintain isolation
between target ground and chassis ground, USB does not hang
Original Post ID: 12782 |
Ivar Boer Guest
Posted: Tue Mar 18, 2003 9:18 am |
:=:=Hello programmers,
:=:=In my application iam using a PIC16F877A processor with an ICD2 (and MPLAB IDE 6.13) for in circuit programming. USB is used for connection between PC and ICD2. An external adapter is connected to the ICD2 (someone said this is neccessary to source enough current when using USB)
:=:=When iam programming my processor using the supply of the ICD2 (adjusted in MPLAB) my application does strange things (like an instable fan PI-controlling)
:=:=When iam programming my processor using the supply of my PCB my application works properly.
:=:=Please! contact me if someone knows about this problem.
:=:=I have also discovered an EEPROM error on address 0x63 of my EEPROM (I programm 0xFF and 0x77 is read when verifying). I don't know if this has something to do with it.
:=:=Thanks to you all.
:=:=Ivar
:=I've had trouble with having my target digital ground
:=connected to chassis ground. If I maintain isolation
:=between target ground and chassis ground, USB does not hang
Thanks for your response, but this isn't the problem.
I also discovered that the self-test isn't passed, but i can programm anyway.
See self-test info below:
Target Vdd: Pass
Moddule Vpp: High
MCLR Gnd: Pass
MCLR Vdd: Pass
MCLR Vpp: High
See voltages (shown in MPLAB IDE) below:
Target Vdd: 5.12V
Target Vpp: 13.10V
MPLAB ICD2 Vpp: 13.18V
Original Post ID: 12788 |
