adc on 18f4550
krodkey
adc on 18f4550
PostPosted: Wed Jul 12, 2006 6:57 am     Reply with quote
Does anyone know what the conversion equation is to convert the value obtained from read_adc() on a 18f4550 chip to volts DC?
PostPosted: Wed Jul 12, 2006 7:08 am     Reply with quote
It depends on your Vref.
(Vref/1024)*ADC_READING
Note that the divider is 1024, though the output of the ADC, is 0-1023. Also that this will need to be done in floating point arithmetic (slow and bulky). Using a scaled integer is much quicker fo most applications.
krodkey78
adc on 18f4550
PostPosted: Wed Jul 12, 2006 10:20 am     Reply with quote
I used the equation and it seems to be working but the voltages will not swing into the negative range. I am collecting the analog data from strain guages that are connected to a fiberglass arm. When the arm bend the resistance changes. Bend it one way and the voltage should go positive and bend it the other is should go negative. I am not sure how to read the negative values from adc. It just returns to 0. Below is the code I am using.
        //init
   setup_adc_ports(AN0|VSS_VREF);
   setup_adc(ADC_CLOCK_DIV_16);
        set_adc_channel(0);
   port_b_pullups(TRUE);
      setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
      setup_timer_0(RTCC_INTERNAL);
      setup_timer_1(T1_DISABLED);
      setup_vref(VREF_HIGH|VREF);
      lcd_init();
      setup_low_volt_detect(FALSE);
   setup_oscillator(FALSE);
//usage of adc
#define VREF 12.0
long sample = 0;
float volts = 0.0;
sample = read_adc();
volts = (VREF/1024.0) * (float)(sample);
Any help would be much appreciated.
treitmey
PostPosted: Wed Jul 12, 2006 10:46 am     Reply with quote
page 399
http://ww1.microchip.com/downloads/en/DeviceDoc/39632c.pdf
It shows range from VREFlow to VREFhigh
and VREFlow can only go down to Vss-0.3 ie the PICs ground.
I think you would need and opamp of some configuration to shift and scale
your reading to fit inside the 0-5V range.
