seoman_79
Help: 18f452 I2c |
Posted: Tue Jul 11, 2006 4:54 am |
Hi, this is my first time!
so, i have a PIC 18f452 and i am trying to use i2c bus,using CCS Compiler
#use i2c(Slave,Fast,sda=PIN_C4,scl=PIN_C3,restart_wdt,force_hw,address=0xa0)
#int_ssp
void SSP_isr() {
restart_wdt();
printf(" i2c");
main(){
output_flow(PIN_C3);
output_flow(PIN_C4);
i have an ideal start Condition on the bus,and the rigt address (my signal si about 50Hz),but the interupt seems not to work well.
Anyone can help me,please?
Thanks,
mario |
treitmey
Posted: Tue Jul 11, 2006 8:37 am |
1. Post code using the "code" button. It retains the format.
2. Post complete code. You don't have any PIC info
3. Always have a forever while loop at the end of the test to prevent the PIC from going to sleep.((CCS compiles puts this sleep command in for you))
4. There isn't a function output_flow.. I figured you wanted output_low, but this would in turn override the I2C code
5. You never turned on the interupts. To do this enable the int you want to use, provide a ISR and turn on interupts global.
try this
Code: | #include <18F452>
#use delay(clock=40000000)
#fuses h4,nowdt,noprotect,nolvp,put
#use rs232(baud=19200,xmit=PIN_C0,invert,stream=DEBUG,disable_ints) // stderr(same as debug)
#case
#zero_ram
//#use I2C(MASTER,SDA=FRAM_SDA,SCL=FRAM_SCL,FORCE_HW,FAST=1000000,RESTART_WDT)
int1 print_it_flag=FALSE;
void main(void){
printf("\n\rStart\n\r");
//output_low(PIN_C3);//can't do this, it will override the I2C code
//output_low(PIN_C4);//can't do this, it will override the I2C code
//remember a 10k pull-up resistor on the I2C lines sda,scl
enable_interrupts(INT_SSP);
while(TRUE) //ie while(1) while(TRUE) ie forever while loop
if(print_it_flag){
printf(" i2c");
#INT_SSP
void SSP_isr() {
restart_wdt();
print_it_flag=TRUE;
..edited for note below
...edited for 2nd note below
Posted: Tue Jul 11, 2006 9:44 am |
Also though, do not pull the C3/C4 pins down. The slave, needs to listen to the pins, and only activate the data pin when ordered to do so. At present, the code is setting the pins as outputs, and pulling the data and clock line low, thereby overriding the I2C peripheral, which can therefore not work.
rnielsen
Posted: Tue Jul 11, 2006 1:52 pm |
One word of advice, never _ever_ put a printf() statement inside an interrupt handler. Printf() can create a massive amount of code and an interrupt needs to be as short as possible. Set a variable, inside the interrupt, and then evaluate it in main(). If it is set then print something and clear the variable. You'll find this is the better way to do things as you begin to write more extensive and complicated code.
Ronald |
