James Guest
Need some help #locating some data in the wrong endian |
Posted: Fri Jun 02, 2006 1:27 pm |
I posted this in another thread but its offtopic now and I can't really figure it out. I did search, but found very little on endians. Also, I'm locating a struct to my data for a good reason, its a little odd but it does exactly what I want, so onto my problem:
int data[8];
struct struct_spi {
int16 block1;
int16 block2;
int bitmapped;
struct struct_spi mySPIstruct
#locate mySPIstruct = data
Which works great! Except for one thing. The values in data[] come from the source in the wrong endian. So, say my
data = 0x11,0x22,0x33,0x44,0x55
What I want is:
mySPIstruct.block1 = 0x1122
mySPIstruct.block2 = 0x3344
mySPIstruct.bitmapped = 0x55
but ofcourse when I run this I get:
mySPIstruct.block1 = 0x2211
mySPIstruct.block2 = 0x4433
mySPIstruct.bitmapped =0x55
Is there a way to use locate and structs to solve this without swapping variables at runtime? Just adjusting the struct, not screwing up the order of values in data[] or any new structs that I locate in the same spot.
Thank You Everyone, |
Posted: Fri Jun 02, 2006 2:04 pm |
I don't see how it can be done, because int16 inherently stores data
in Lo-Hi format. It seems to me that you're looking for some pragma
that will automatically swap the bytes for you, by inserting appropriate
ASM code. I don't think it exists. I think that, in your routine that
loads the array, you need to add code to do the byte swapping right
after the array is loaded. |
Posted: Fri Jun 02, 2006 2:59 pm |
Hmm... Problem with that is since the two share memory locations I'll be changing data[] too.
On second thought I agree that I can't do what I wanted to. Unless there is someway to specify the location to each half of an int16.
The whole reason I wanted to get away from this is that I'm always pulling data in and sometimes I need them swaped, was trying to save from doing the very repetitive:
temp = (int16)data[0] << 8;
temp += data[1];
And if I define a struct I can access my data by meaningful name. Maybe I'll just do both, swap and use the struct for fun. Oh well.
Maybe there is a better way to swap then what I was doing ? |
Posted: Fri Jun 02, 2006 5:17 pm |
Code: | temp = (int16)data[0] << 8;
temp += data[1]; | On a PIC18 this takes 14 bytes, 7 clock cycles.
Shorter is Code: | temp = make16(data[0], data[1]); | 8 bytes, 4 clock cycles. |
