		| Author | Message |
		| global
				| Address with the DS2438 battery monitor |
				|  Posted: Mon Mar 27, 2006 6:39 am |   |
				| Hello, I'm using the DS2438 for monitoring a 10V NiMh battery, i need to read the voltage register and the current register.
 So in the datasheet, the current register is in the page 0 byte 3 and 4. So i don't know how to wrote the address in my program the page is the first byte and the byte the second;
 0x03 for page 0 byte 3
 0x12 for page 1 byte 2
 This is my code to read the voltage register :
 void ReadVoltage (void)
 if(!Reset())
 WriteByte(SkipNetAdress);     // SkipNetAdress Command
 WriteByte(Read);                  // Read Registers Command
 WriteByte(0x03);                  // Voltage Register Address
 Voltage=ReadByte();
 Voltage= Voltage<<8;
 Voltage = Voltage+ReadByte();
 Tension=((float)Voltage)*1/100;    //10mV volt/bit, la pr飩sion n'est
		| treitmey
				|  Posted: Mon Mar 27, 2006 9:39 am |   |
				| I think you are confusing a nibble and a byte.
  	  | Quote: |  	  | the page is the first byte and the byte the second; |
 above where you state 0x03 is page0 byte 3, I think you want
 0x0003
 And in the code you would have an extra writebyte()
 it would be
  	  | Code: |  	  | WriteByte(SkipNetAdress); // SkipNetAdress Command
 WriteByte(0x00); // Voltage Register Address
 Voltage=ReadByte();
		| global
				|  Posted: Wed Mar 29, 2006 1:46 am |   |
				| it doesn't working, i already use this code for the DS2770, i think i can use the same code, i just need to modify the adress. I don't know why it's not working. |  |
		| global
				|  Posted: Fri Mar 31, 2006 1:38 am |   |
				| Its now working, this is the code that we need to use, first read all the register, and to recover the data, we need to read the scratchpad:
 if(!Reset())
 WriteByte(0xCC);    //skip ROM
 WriteByte(0x44);    //read temperature slot
 if(!Reset())
 WriteByte(0xB4);    //read voltage slot
 if(!Reset())
 WriteByte(0xB8);    //call memory page 00
 WriteByte(0x00);
 if(!Reset())
 WriteByte(0xBE);    //read page 00
 WriteByte(0x00);
 if(!Reset())
 WriteByte(0xBE);    //read scratchpad
 WriteByte(0x00);
 //read 9 bytes of data
 Variable1=ReadByte();
 Variable2=ReadByte();
 Variable3=ReadByte();
 Variable4=ReadByte();
 Variable5=ReadByte();
 Variable6=ReadByte();
 Variable7=ReadByte();
 Variable8=ReadByte();
 Variable9=ReadByte();
