Paul Klissner Guest
Why is my 16F628 Resetting? |
Posted: Mon Nov 19, 2001 1:14 am |
The same sort of code on an earlier version
of the compiler worked fine on a 16F84.
On the 16F628, regardless of fuse settings,
and other settings.
#fuses INTRC_IO,NOWDT,NOLVP,MCLR,NOPROTECT,NOPUT,NOBROWNOUT
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
setup_vref(FALSE);
disable_interrupts(GLOBAL);
disable_interrupts(INT_RTCC);
disable_interrupts(INT_CCP1);
disable_interrupts(INT_EEPROM);
disable_interrupts(INT_EXT);
disable_interrupts(INT_LCD);
disable_interrupts(INT_RB);
disable_interrupts(INT_TBE);
disable_interrupts(INT_RDA);
disable_interrupts(INT_COMP);
disable_interrupts(INT_TIMER1);
disable_interrupts(INT_TIMER2);
I'm using INTRC_IO, MCLR tied to Vdd externally.
I've tried disabling all interrupts. I'm using the
EPIC PICPlus Programmer from <a href="http://www.melabs.com" TARGET="_blank">http://www.melabs.com</a>
I've got solid 4.98 volts across Vdd and Vss with
a capacitor.
Simple and some complex instructions work, but certain
array accesses and printf() statements to the LCD cause
it to reset.
First I thought "Its the compiler"..
Then I thought "no", it couldn't be the compiler.
Now I'm back to wondering if its the compiler again.
Any ideas? Any reason to think it is some significant
difference between the '628 and the '84, or a problem
with 3.059 of the compiler?
Any help appreciated.
___________________________
Original Post ID: 1219 |
Paul Klissner Guest
Re: Why is my 16F628 Resetting? |
Posted: Mon Nov 19, 2001 1:37 am |
Aha! Finally. I'm using the EPIC programmer from the
command line, and it had been so long since I had
looked at the options that I didn't bother to specify
the 16F628 as the device. It required an upgrade for the
EPIC software from their site (I used beta 2.40) and
added the -d16F628 flag and whalla!
-Paul
:=The same sort of code on an earlier version
:=of the compiler worked fine on a 16F84.
:=On the 16F628, regardless of fuse settings,
:=and other settings.
:=#fuses INTRC_IO,NOWDT,NOLVP,MCLR,NOPROTECT,NOPUT,NOBROWNOUT
:= setup_timer_0(RTCC_INTERNAL);
:= setup_timer_1(T1_DISABLED);
:= setup_timer_2(T2_DISABLED,0,1);
:= setup_ccp1(CCP_OFF);
:= setup_ccp2(CCP_OFF);
:= setup_vref(FALSE);
:= setup_comparator(NC_NC_NC_NC);
:= disable_interrupts(GLOBAL);
:= disable_interrupts(INT_RTCC);
:= disable_interrupts(INT_CCP1);
:= disable_interrupts(INT_EEPROM);
:= disable_interrupts(INT_EXT);
:= disable_interrupts(INT_LCD);
:= disable_interrupts(INT_RB);
:= disable_interrupts(INT_TBE);
:= disable_interrupts(INT_RDA);
:= disable_interrupts(INT_COMP);
:= disable_interrupts(INT_TIMER1);
:= disable_interrupts(INT_TIMER2);
:=I'm using INTRC_IO, MCLR tied to Vdd externally.
:=I've tried disabling all interrupts. I'm using the
:=EPIC PICPlus Programmer from <a href="http://www.melabs.com" TARGET="_blank"> <a href="http://www.melabs.com" TARGET="_blank">http://www.melabs.com</a></a>
:=I've got solid 4.98 volts across Vdd and Vss with
:=a capacitor.
:=Simple and some complex instructions work, but certain
:=array accesses and printf() statements to the LCD cause
:=it to reset.
:=First I thought "Its the compiler"..
:=Then I thought "no", it couldn't be the compiler.
:=Now I'm back to wondering if its the compiler again.
:=Any ideas? Any reason to think it is some significant
:=difference between the '628 and the '84, or a problem
:=with 3.059 of the compiler?
:=Any help appreciated.
Original Post ID: 1221 |
adrian
Posted: Tue Nov 20, 2001 6:41 am |
If you change your #fuses to NOMCLR, it will be tied to Vdd internally, so you don't need to do it externally.
Original Post ID: 1247 |
