Cam Bruce
RTCC messing up RS232 ? |
Posted: Thu Nov 08, 2001 4:20 pm |
Well, there went the afternoon....
I tried to add serial output to a previous program. I find that the baud rate out is slower than what I specify in #use rs232...
I have simplified the code down to this, and I get a jumpy square wave, at about 900Hz out C6
If I remark out the ENABLE_INTERRUPTS(INT_RTCC); line, everything works fine...clean square wave at 1200Hz
I want to use the WDT, so setup_counters defaults to RTCC_DIV_1.
And, I plan to use the Seconds counter to take readings every 15 min.
Any suggestions?
#include <16F877.H>
#fuses HS,NOPROTECT,noWDT,PUT,NOLVP //WDT disabled for testing, NEEDS re-enabled
#use delay(clock=4000000) //USING A 4MHz CRYSTAL
#use standard_io(C)
#use rs232(baud=2400, xmit=PIN_C6, rcv=PIN_C4)
#byte porta=5 //These lines define the Ports.
#byte portb=6
#byte portc=7
#byte portd=8
#byte porte=9
#define INTS_PER_SECOND 3906 // (4000000/(4*256))
LONG SECONDS=0; //a running real time counter. starts at 0 on reset, counts forever.
long int_count; //interrupts left before a second has gone by.
//// THE NEXT LINES ARE THE RTCC INTERRUPT ROUTINE. ////
#int_rtcc // This function is called every time
clock_isr() // the RTCC (timer0) overflows (255->0).
{ // For this program this is 3906 times
if(--int_count==0) // per second with a 4MHz crystal.
{++SECONDS;
int_count=INTS_PER_SECOND; //set counter up to 3906 again.
//// END OF INTERRUPT SERVICE ROUTINE ////
main()
SETUP_COUNTERS(RTCC_INTERNAL,WDT_2304MS);//...2.304 Sec before Watch dog Reset.
enable_interrupts(global);
ENABLE_INTERRUPTS(INT_RTCC); //RTCC (Timer0) used for real time clock.
while(true) //for testing
putc(0x55); //for testing
} //end of Main.
Original Post ID: 1023 |
Re: RTCC messing up RS232 ? |
Posted: Thu Nov 08, 2001 5:52 pm |
:=I tried to add serial output to a previous program. I find that the baud rate out is slower than what I specify in #use rs232...
:=I have simplified the code down to this, and I get a jumpy square wave, at about 900Hz out C6
:=If I remark out the ENABLE_INTERRUPTS(INT_RTCC); line, everything works fine...clean square wave at 1200Hz
If you use a software USART, the timing of the pulses is
controlled by software delay loops. If you have an interrupt
occuring during that delay loop, then the delay will be longer
than intended.
Two possible solutions:
1. Use the hardware USART.
2. Disable interrupts when using the software USART.
Original Post ID: 1024 |
Cam Bruce
Posted: Fri Nov 09, 2001 8:23 am |
:=:=I tried to add serial output to a previous program. I find that the baud rate out is slower than what I specify in #use rs232...
:=:=I have simplified the code down to this, and I get a jumpy square wave, at about 900Hz out C6
:=:=If I remark out the ENABLE_INTERRUPTS(INT_RTCC); line, everything works fine...clean square wave at 1200Hz
:=If you use a software USART, the timing of the pulses is
:=controlled by software delay loops. If you have an interrupt
:=occuring during that delay loop, then the delay will be longer
:=than intended.
:=Two possible solutions:
:=1. Use the hardware USART.
:=2. Disable interrupts when using the software USART.
That makes sence.
I think I'll go with disabling the interrupts during the serial data.
Does that mean the delay_ms() and Delay_us() will also interfere with the RTCC?
Thanks Again Cam
Original Post ID: 1033 |
