Infrared receiver for SONY remotes
Goto page Previous  1, 2
acidice333
PostPosted: Tue Nov 29, 2011 2:47 am     Reply with quote
Just curious how do you calculate for 48mhz? its probably right in front of me and I just dont understand. Much appreciated thanks!
/* TIMER0 configuration */
#define TIMER0_CONFIG RTCC_INTERNAL | RTCC_DIV_1
/* Interrupt rate: */
/* 4/32000000*65536*1 = 8.192 ms */
/* Start: 3.0 ms (ignored) */
/* "1": 1.8 ms (14400) */
/* "0": 1.2 ms (9600) */
#define ONE_MIN 13400
#define ONE_MAX 15400
#define ZERO_MIN 8600
#define ZERO_MAX 10600
sahu77
PostPosted: Fri Dec 23, 2011 11:19 am     Reply with quote
Anybody can convert it code in RC5 for help me ....
sahu
masterat
PostPosted: Tue Jan 03, 2012 1:33 am     Reply with quote
48 Mhz Should be:
/* 4/48000000*65536*1 = 5.46125 ms       */
/*     "1":   1.8 ms (21600)           */
/*     "0":   1.2 ms  (14400)           */
#define ONE_MIN  22600
#define ONE_MAX  20600
#define ZERO_MIN 13400
#define ZERO_MAX 15400
rdoradus
answer
PostPosted: Mon Jan 07, 2013 10:18 pm     Reply with quote
The answer for HTAluvBeBeo is only work with #fuses. I compile the code for send with RS-232 and proved with pickit2 clone and it works great
I have written next fuses in header:
#include <18f4550.h>
#FUSES HS,NOWDT,WDT128,NOPROTECT,NOBROWNOUT,BORV20,PUT,MCLR,NOCPD,NODEBUG,NOLVP,NOWRT,NOWRTD,NOWRTB,NOEBTR,NOEBTRB,NOCPB,NOWRTC,NOFCMEN,NOPBADEN,PLL1,CPUDIV1,USBDIV,VREGEN,ICPRT,STVREN,NOIESO,LPT1OSC,NOXINST
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_B7, rcv=PIN_B6)
#use fast_io(B)
/* 4/20000000*65536*1 = 13.1072 ms    5.46125   */
/*     "1":   1.8 ms (9000)          7.28177777 */
/*     "0":   1.2 ms  (6000)          10.922666 */
#define ONE_MIN 8000
#define ONE_MAX 10000
#define ZERO_MIN 5000
#define ZERO_MAX 7000
All extra code equal...
Crystal of 20MHz PIC18F2550 and RS-232 from Pickit2 clone.
loctip
Re: Infrared receiver for SONY remotes
PostPosted: Sun May 12, 2013 10:33 pm     Reply with quote
Plz show me how to calculate these datas !
Thanks a lot
14400 9600
Page 2 of 2
