I have two inputs I need to send to PORTC. 1st input needs to go on 1st 4 bits and 2nd input needs to go next 4bits. How can I do that. Should I use output_portc(value) and send it twice or there is other way of doing this.
Original Post ID: 12421
Mark
Re: Two inputs to Portc
Posted: Thu Mar 06, 2003 12:06 pm
Here is one such example:
data1 = 0x03;
data2 = 0x02;
temp = (data2<<4)&(data1&0x0f);
PORTC = temp;
:= I have two inputs I need to send to PORTC. 1st input needs to go on 1st 4 bits and 2nd input needs to go next 4bits. How can I do that. Should I use output_portc(value) and send it twice or there is other way of doing this.
Original Post ID: 12433
Posted: Thu Mar 06, 2003 1:29 pm
It seems like you're describing an LCD interface.
See the CCS example file, LCD.C, which shows how
to define several bits as a element of a structure.
Then you can write to those 4 bits with one line of code.
The LCD.C file is in this folder:
c:\Program Files\Picc\Drivers
Original Post ID: 12439
