specialk
| Laipac RF-24G / TXRX24G 2.4GHz Wireless Transceiver Driver |
Posted: Sat Jan 21, 2006 12:47 pm |
Works well with my configuration
| Code: | ////////////////////////////////////////////////////////////////////////////////
// Laipac RF-24G / TXRX24G
// 2.4GHz Wireless Transceiver Driver
// Original by micro222@yahoo.com
// Filenmae : RF-24G.c
// Programmer : Steven Cholewiak, www.wahoo-wa.net
// Version : Version 1.0 - 01/21/2006
// Remarks : Datasheets for RF-24G / TXRX24G are available from:
// http://www.sparkfun.com/datasheets/RF/RF-24G_datasheet.pdf
// http://www.sparkfun.com/datasheets/RF/RF-24G.pdf
// http://www.sparkfun.com/datasheets/RF/nRF2401rev1_1.pdf
// http://store.qkits.com/moreinfo.cfm/txrx24g.pdf
// This code is modified from the original to support more
// configuration options with more information provided about
// each configuration byte.
//Pin Configuration
// Pin Name Pin funtion Description
// 1 GND Power Gound (0V)
// 2 CE Input Chip Enable activates RX or TX mode
// 3 CLK2 I/O Clock output/input for RX data channel 2
// 4 CS Input Chip Select activates Configuration mode
// 5 CLK1 I/O Clock Input(TX)&I/O(RX) for data channel 1 3-wire interface
// 6 DATA I/O RX data channel 1/TX data input /3-wire interface
// 7 DR1 Output RX data ready at data channel 1 (ShockBurst only)
// 8 DOUT2 Output RX data channel 2
// 9 DR2 Output RX data ready at data channel 2 (ShockBurst only)
// 10 VCC Power Power Supply (+3V DC)
#define RF_24G_CE PIN_A5
#define RF_24G_DATA PIN_A4
#define RF_24G_CLK1 PIN_A3
//#define RF_24G_CLK2 PIN_B0
#define RF_24G_DR1 PIN_A2
#define RF_24G_CS PIN_A1
//#define RF_24G_DOUT2 PIN_B4
//#define RF_24G_DR2 PIN_B7
//Configuration Bytes
//Bytes 14-02: Shockburst Configuration
//Bytes 01-00: General Device Configuration
//Byte 14: Length of data payload section RX channel 2 in bits
// The total number of bits in a ShockBurst RF package may not exceed 256!
// Maximum length of payload section is hence given by:
// DATAx_W(bits) = 256 - ADDR_W - CRC
#define DATA2_W 32 //4 Bytes
//Byte 13: Length of data payload section RX channel 1 in bits
#define DATA1_W 32 //4 Bytes
//Byte 12-08: Channel 2 Address
#define ADDR2_4 0x00
#define ADDR2_3 0x00
#define ADDR2_2 0x00
#define ADDR2_1 0x42
#define ADDR2_0 0x42
//Byte 07-03: Channel 1 Address
#define ADDR1_4 0x00
#define ADDR1_3 0x00
#define ADDR1_2 0x00
#define ADDR1_1 0x42
#define ADDR1_0 0x42
//Byte 02
// Bit 07-02: ADDR_W - Number of address bits (both RX channels)
// Maximum number of address bits is 40 (5 bytes)
// Bit 01: CRC_L - 8 or 16 bits CRC
// Bit 00: CRC_EN - Enable on-chip CRC generation/checking
// Combine (via |) together constants from each group
// 0b76543210
#define ADDR_W_5_BYTE 0b10100000
#define ADDR_W_4_BYTE 0b10000000
#define ADDR_W_3_BYTE 0b01100000
#define ADDR_W_2_BYTE 0b01000000
#define ADDR_W_1_BYTE 0b00100000
#define CRC_L_8_BIT 0b00000000
#define CRC_L_16_BIT 0b00000010
#define CRC_EN_DISABLE 0b00000000
#define CRC_EN_ENABLE 0b00000001
//Byte 01
// Bit 07: RX2_EN - Enable two channel receive mode
// Bit 06: CM - Communication mode ( Direct or ShockBurst)
// Bit 05: RFDR_SB - RF data rate (1Mbps requires 16MHz crystal)
// Bit 04-02: XO_F - Crystal frequency (Factory default 16MHz crystal mounted)
// Bit 01-00: RF_PWR - RF output power
// 0b76543210
#define RX2_EN_DISABLE 0b00000000
#define RX2_EN_ENABLE 0b10000000
#define CM_DIRECT 0b00000000
#define CM_SHOCKBURST 0b01000000
#define RFDR_SB_250_KBPS 0b00000000
#define RFDR_SB_1_MBPS 0b00100000
#define XO_F_4MHZ 0b00000000
#define XO_F_8MHZ 0b00000100
#define XO_F_12MHZ 0b00001100
#define XO_F_16MHZ 0b00001100
#define XO_F_20MHZ 0b00010000
#define RF_PWR_N20DB 0b00000000 // -20db
#define RF_PWR_N10DB 0b00000001 // -10db
#define RF_PWR_N5DB 0b00000010 // -5db
#define RF_PWR_0DB 0b00000011 // 0db (Full Power)
//Byte 01
// Bit 07-01: RF_CH# - Frequency channel (2400MHz + RF_CH# * 1.0MHz)
// Bit 00: RXEN - RX or TX operation
// 0b76543210
#define RF_CH 0b10000000 // 64 - 2464GHz
#define RXEN_TX 0b00000000
#define RXEN_RX 0b00000001
#inline
RF_24G_initPorts() {
PORT_B_PULLUPS(FALSE);
DISABLE_INTERRUPTS(INT_RB);
#define BUF_MAX 4
byte buf[BUF_MAX];
#define CLKDELAY() delay_us(1)
#define CSDELAY() delay_us(10)
#define PWUPDELAY() delay_ms(3)
void putByte( byte b ) { //MSB bit first
int8 i;
int8 p = 7;
for(i=0 ; i < 8 ; i++) {
OUTPUT_LOW(RF_24G_CLK1);
if( BIT_TEST(b,p--) ) {
OUTPUT_HIGH(RF_24G_DATA);
}else{
OUTPUT_LOW(RF_24G_DATA);
CLKDELAY();
OUTPUT_HIGH(RF_24G_CLK1); // Clock out on rising edge
CLKDELAY();
byte getByte() { //MSB bit first
int8 i , b = 0;
int8 p = 7;
CLKDELAY();
CLKDELAY(); // Read before falling edge
if( INPUT(RF_24G_DATA) ) {
BIT_SET(b,p--);
}else{
BIT_CLEAR(b,p--);
return b;
void RF_24G_Config() {
OUTPUT_LOW(RF_24G_CE);
OUTPUT_LOW(RF_24G_CS);
PWUPDELAY();
OUTPUT_HIGH(RF_24G_CS);
CSDELAY();
//MSB byte first
putByte(DATA2_W);
putByte(DATA1_W);
putByte(ADDR2_4);
putByte(ADDR2_3);
putByte(ADDR2_2);
putByte(ADDR2_1);
putByte(ADDR2_0);
putByte(ADDR1_4);
putByte(ADDR1_3);
putByte(ADDR1_2);
putByte(ADDR1_1);
putByte(ADDR1_0);
putByte(ADDR_W_2_BYTE | CRC_L_16_BIT | CRC_EN_ENABLE);
putByte(RX2_EN_DISABLE | CM_SHOCKBURST | RFDR_SB_1_MBPS | XO_F_16MHZ | RF_PWR_0DB);
putByte(RF_CH | RXEN_RX);
OUTPUT_FLOAT(RF_24G_DATA);
void RF_24G_SetTxByte() {
CSDELAY();
putByte(RF_CH | RXEN_TX);
void RF_24G_SetTx() {
// Once the wanted protocol, modus and RF channel are set,
// only one bit (RXEN) is shifted in to switch between RX and TX.
CSDELAY();
CLKDELAY();
CLKDELAY();
void RF_24G_SetRxByte() {
CSDELAY();
OUTPUT_HIGH(RF_24G_CE);
void RF_24G_SetRx() {
CSDELAY();
CLKDELAY();
CLKDELAY();
void putBuffer() {
int8 i;
CSDELAY();
putByte(ADDR1_1);
putByte(ADDR1_0);
for( i=0; i<BUF_MAX ; i++) {
putByte(buf[i]);
void getBuffer() {
int8 i;
buf[i] = getByte();
//Example Setup:
// RF_24G_initPorts();
// RF_24G_Config();
// RF_24G_SetRx(); // Switch to receive
// buf[0] = 'A';
// buf[1] = 'B'; // Not used
// buf[2] = 'C'; // Not used
// buf[3] = 'D'; // Not used
// while(1) {
// if(INPUT(RF_24G_DR1)){
// getBuffer(); // Get packet
// putc(buf[0]);
// // Transmit RF
// RF_24G_SetTx(); // switch to transmit
// delay_ms(1);
// putBuffer(); // send packet (buf)
// delay_ms(1); // won't go back to recieve without this
// RF_24G_SetRx(); // switch back to receive
// delay_ms(1);
-special [k] |
specialk
Posted: Fri Aug 18, 2006 11:01 am |
Here's a slightly modified and updated version:
// Filename : RF-24G_6-byte.c
// Programmer : Steven Cholewiak, www.semifluid.com
// Version : Version 1.01 - 01/30/2006
// History : Version 1.01 - 01/30/2006
// - numOfBytes is now used to describe the packet payload and
// adjusts DATA1_W, DATA2_W, and BUF_MAX accordingly
// Version 1.00 - 01/21/2006
// - Initial release
//Pin Configuration
#define RF_24G_CE PIN_B3
#define RF_24G_DATA PIN_B4
#define RF_24G_CLK1 PIN_B5
#define RF_24G_DR1 PIN_B6
#define RF_24G_CS PIN_B7
#define numOfBytes 6
#inline
#define DATA2_W numOfBytes * 8
#define DATA1_W numOfBytes * 8
//Byte 02
// 0b76543210
//Byte 01
// 0b76543210
//Byte 01
// 0b76543210
#define BUF_MAX numOfBytes
byte buf[BUF_MAX];
int8 i;
int8 p = 7;
}else{
CLKDELAY();
CLKDELAY();
int8 i , b = 0;
int8 p = 7;
CLKDELAY();
BIT_SET(b,p--);
}else{
BIT_CLEAR(b,p--);
return b;
PWUPDELAY();
CSDELAY();
//MSB byte first
putByte(DATA2_W);
putByte(DATA1_W);
putByte(ADDR2_4);
putByte(ADDR2_3);
putByte(ADDR2_2);
putByte(ADDR2_1);
putByte(ADDR2_0);
putByte(ADDR1_4);
putByte(ADDR1_3);
putByte(ADDR1_2);
putByte(ADDR1_1);
putByte(ADDR1_0);
CSDELAY();
CSDELAY();
CLKDELAY();
CLKDELAY();
CSDELAY();
CSDELAY();
CLKDELAY();
CLKDELAY();
void putBuffer() {
int8 i;
CSDELAY();
putByte(ADDR1_1);
putByte(ADDR1_0);
putByte(buf[i]);
void getBuffer() {
int8 i;
buf[i] = getByte();
//Example Setup:
// RF_24G_Config();
// buf[0] = 'A';
// while(1) {
// putc(buf[0]);
// // Transmit RF
// delay_ms(1);
// delay_ms(1);
future
Posted: Sat Sep 19, 2009 1:25 pm |
Hi specialk,
How far can you stream data with this transceiver? |
