		| Author | Message |
		| Humberto
				| Unable to load FT2dxx drivers |
				|  Posted: Thu Dec 01, 2005 12:41 pm |   |
				| Had working with the ICD-S in a reliable way until I decided to update to the last ICD-S version.
 The ICD control program works fine when in stand alone Mode, passes all tests, comm, downloads, etc but in the debugger mode do not.
 In Debug Mode, when I press the Reset icon, gives a window error with the following mssge:
 "Unable to load FT2dxx drivers"
 I tryied to go back to previous version but the mssge is still on there, the debugger doesnīt load nothing and in the bottom side it shows No Communication with a red background.
 Do I miss something ? Not found any help related with this in troubleshooting section.
 Any help will be very well appreciated.
 Many thanks in advance.
 Humberto
		| Nandini
				|  Posted: Fri Dec 02, 2005 10:02 am |   |
				| What is the PCW/PCWH version? Make sure ICD Serial is selected in the Debug Configure tab. |  |
		| Humberto
				|  Posted: Fri Dec 02, 2005 11:11 am |   |
				|  	  | Quote: |  	  | Make sure ICD Serial is selected in the Debug Configure tab.
 YES !!! Thatīs the answer man. (I canīt see it because the DEBUG option was disabled at start up and the Debug Configuration label was hidden.)
 Nandini many thanks !
 Humberto
