Writing eeprom isn't working for me.
Dario
PostPosted: Tue Nov 15, 2005 10:16 pm     Reply with quote
I am trying to write a data table to eeprom on the 16F873A. I would like the device to perform and A to D (8-bit) on A0, and pull data out of the resultant eeprom address. The data is then output to the ports as a 3 bit decimal number.
This code was working and displaying the A-D conversion.
#include <16F873A.h>
#device adc=8
#fuses NOWDT,HS, NOPUT, NOPROTECT, NODEBUG, BROWNOUT, NOLVP, NOCPD, NOWRT
   int value, hunten, hund, tens, ones;
   setup_adc_ports(AN0_AN1_VSS_VREF); //VREF = A3
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   set_tris_b(0x00);
   set_tris_c(0x00);
   set_adc_channel(0);
while ( TRUE )
   value = read_adc();
   hund = value / 100;
   value = value % 100;
   tens = value / 10;
   ones = value % 10;
   hunten = 16*hund + tens;
   output_b(hunten);
   output_c(ones);
   delay_ms(2000);
I then tried to create the eeprom lookup table and i get only 0's on the output. I know there must be easier ways but i thaught this might work.
#device adc=8
   int data, value, hunten, hund, tens, ones;
   setup_spi(FALSE);
   setup_vref(FALSE);
   set_tris_b(0x00);
   set_tris_c(0x00);
   set_adc_channel(0);
//***** WRITE DATA TABLE TO EEPROM******//
   write_eeprom(   15   ,   112   );
   write_eeprom(   16   ,   104   );
   write_eeprom(   17   ,   97   );
   write_eeprom(   18   ,   90   );
   write_eeprom(   19   ,   85   );
   write_eeprom(   20   ,   80   );
   write_eeprom(   21   ,   75   );
   write_eeprom(   22   ,   71   );
   write_eeprom(   23   ,   68   );
   write_eeprom(   24   ,   64   );
   write_eeprom(   25   ,   61   );
   write_eeprom(   26   ,   58   );
   write_eeprom(   27   ,   56   );
   write_eeprom(   28   ,   54   );
   write_eeprom(   29   ,   51   );
   write_eeprom(   30   ,   49   );
   write_eeprom(   31   ,   47   );
   write_eeprom(   32   ,   46   );
   write_eeprom(   33   ,   44   );
   write_eeprom(   34   ,   42   );
   write_eeprom(   35   ,   41   );
   write_eeprom(   36   ,   40   );
   write_eeprom(   37   ,   38   );
   write_eeprom(   38   ,   37   );
   write_eeprom(   39   ,   36   );
   write_eeprom(   40   ,   35   );
   write_eeprom(   41   ,   34   );
   write_eeprom(   42   ,   33   );
   write_eeprom(   43   ,   32   );
   write_eeprom(   44   ,   31   );
   write_eeprom(   45   ,   30   );
   write_eeprom(   46   ,   30   );
   write_eeprom(   47   ,   29   );
   write_eeprom(   48   ,   28   );
   write_eeprom(   49   ,   27   );
   write_eeprom(   50   ,   27   );
   write_eeprom(   51   ,   26   );
   write_eeprom(   52   ,   26   );
   write_eeprom(   53   ,   25   );
   write_eeprom(   54   ,   24   );
   write_eeprom(   55   ,   24   );
   write_eeprom(   56   ,   23   );
   write_eeprom(   57   ,   23   );
   write_eeprom(   58   ,   22   );
   write_eeprom(   59   ,   22   );
   write_eeprom(   60   ,   22   );
   write_eeprom(   61   ,   21   );
   write_eeprom(   62   ,   21   );
   write_eeprom(   63   ,   20   );
   write_eeprom(   64   ,   20   );
   write_eeprom(   65   ,   20   );
   write_eeprom(   66   ,   19   );
   write_eeprom(   67   ,   19   );
   write_eeprom(   68   ,   19   );
   write_eeprom(   69   ,   18   );
   write_eeprom(   70   ,   18   );
   write_eeprom(   71   ,   18   );
   write_eeprom(   72   ,   17   );
   write_eeprom(   73   ,   17   );
   write_eeprom(   74   ,   17   );
   write_eeprom(   75   ,   16   );
   write_eeprom(   76   ,   16   );
   write_eeprom(   77   ,   16   );
   write_eeprom(   78   ,   16   );
   write_eeprom(   79   ,   15   );
   write_eeprom(   80   ,   15   );
   write_eeprom(   81   ,   15   );
   write_eeprom(   82   ,   15   );
   write_eeprom(   83   ,   15   );
   write_eeprom(   84   ,   14   );
   write_eeprom(   85   ,   14   );
   write_eeprom(   86   ,   14   );
   write_eeprom(   87   ,   14   );
   write_eeprom(   88   ,   14   );
   write_eeprom(   89   ,   13   );
   write_eeprom(   90   ,   13   );
   write_eeprom(   91   ,   13   );
   write_eeprom(   92   ,   13   );
   write_eeprom(   93   ,   13   );
   write_eeprom(   94   ,   12   );
   write_eeprom(   95   ,   12   );
   write_eeprom(   96   ,   12   );
   write_eeprom(   97   ,   12   );
   write_eeprom(   98   ,   12   );
   write_eeprom(   99   ,   12   );
   write_eeprom(   100   ,   12   );
   write_eeprom(   101   ,   11   );
   write_eeprom(   102   ,   11   );
   write_eeprom(   103   ,   11   );
   write_eeprom(   104   ,   11   );
   write_eeprom(   105   ,   11   );
   write_eeprom(   106   ,   11   );
   write_eeprom(   107   ,   11   );
   write_eeprom(   108   ,   11   );
   write_eeprom(   109   ,   10   );
   write_eeprom(   110   ,   10   );
   write_eeprom(   111   ,   10   );
   write_eeprom(   112   ,   10   );
   write_eeprom(   113   ,   10   );
   write_eeprom(   114   ,   10   );
   write_eeprom(   115   ,   10   );
   write_eeprom(   116   ,   10   );
   write_eeprom(   117   ,   10   );
   write_eeprom(   118   ,   9   );
   write_eeprom(   119   ,   9   );
   write_eeprom(   120   ,   9   );
   write_eeprom(   121   ,   9   );
   write_eeprom(   122   ,   9   );
   write_eeprom(   123   ,   9   );
   write_eeprom(   124   ,   9   );
   write_eeprom(   125   ,   9   );
   write_eeprom(   126   ,   9   );
   write_eeprom(   127   ,   9   );
while ( TRUE )
   data = read_adc();
   value = read_eeprom(data);
   hund = value / 100;
   tens = value / 10;
   ones = value % 10;
   output_b(hunten);
   output_c(ones);
   delay_ms(2000);
The compiler tells me out of ROM but the 16F873A has 128 bytes (8-bit) of eeprom. I then tried deleting until it worked. It would compile after everything lower than 80 is deleted and the says 51% full. makes me think it wants a hex address but i have read that decimal should be fine. If anyone has a solution or a way around this to get me reading off some sort of preprogrammed table with every A-D conversion the help would be great.
Thanks.
PostPosted: Tue Nov 15, 2005 11:19 pm     Reply with quote
ROM does not mean eeprom. It means the main program memory.
I compiled your program with PCM vs. 3.239 and it only used 190 words
of ROM and 14 bytes of RAM. I don't see how you can be running
out of ROM.
There are a few problems with your program. You're reading an 8-bit
value from the A/D, which can range from 0 to 255. Then you're
using that value as an index into eeprom which only exists at addresses
from 0 to 127. Also, you haven't initialized addresses 0 to 14 in the
eeprom.
You have enabled Vref on pin RA3. Are you applying a reference
voltage to that pin ?
If you want to have a lookup table, it would be a lot easier if you
put it in program memory instead of data eeprom. Then you can
initialize the table at compile-time, instead of at run-time as you are
doing. Example:
#include <16F873A.H>
#use delay(clock = 4000000)
int8 const lookup_table[] =
   0,1,2,3,4,5,6,7,8,9
  10,11,12,13,14,15,16,17,18,19,
  20,21,22,23,24,25,26,27,28,29,
  30,31,32,33,34,35,36,37,38,39,
  40,41,42,43,44,45,46,47,48,49,
  50,51,52,53,54,55,56,57,58,59,
  60,61,62,63,64,65,66,67,68,69,
  70,71,72,73,74,75,76,77,78,79,
  80,81,82,83,84,85,86,87,88,89,
  90,91,92,93,94,95,96,97,98,99,
  100,101,102,103,104,105,106,107,108,109,
  110,111,112,113,114,115,116,117,118,119,
  120,121,122,123,124,125,126,127
int8 i;
// Display the lookup table.
for(i = 0; i < sizeof(lookup_table); i++)
    printf("%u \n\r", lookup_table[i]);
kender
PostPosted: Tue Nov 15, 2005 11:48 pm     Reply with quote
Wow, it's the first time I see the lookup table in the EEPROM. It could be a neat trick for creating dynamic lookup table. I know I should probably read the datasheet for this (and I will), but how does the read time compare for the on-chip EEPROM, ROM and RAM?
Sincerely,
~K
PostPosted: Wed Nov 16, 2005 1:04 am     Reply with quote
Thanks I'll give the data table a go how you've suggested
