Humberto
| Unable to load FT2dxx drivers |
Posted: Thu Dec 01, 2005 12:41 pm |
Had working with the ICD-S in a reliable way until I decided to update to the last ICD-S version.
The ICD control program works fine when in stand alone Mode, passes all tests, comm, downloads, etc but in the debugger mode do not.
In Debug Mode, when I press the Reset icon, gives a window error with the following mssge:
"Unable to load FT2dxx drivers"
I tryied to go back to previous version but the mssge is still on there, the debugger doesnīt load nothing and in the bottom side it shows No Communication with a red background.
Do I miss something ? Not found any help related with this in troubleshooting section.
Any help will be very well appreciated.
Many thanks in advance.
Humberto |
Nandini
Posted: Fri Dec 02, 2005 10:02 am |
| What is the PCW/PCWH version? Make sure ICD Serial is selected in the Debug Configure tab. |
Humberto
Posted: Fri Dec 02, 2005 11:11 am |
| Quote: |
YES !!! Thatīs the answer man. (I canīt see it because the DEBUG option was disabled at start up and the Debug Configuration label was hidden.)
Nandini many thanks !
Humberto |
