ICD-U40
newpic
ICD-U40
PostPosted: Mon Aug 22, 2005 8:52 am     Reply with quote
I have problem using the ICD-40 as programmer.
Anybody has solution??
Please help...
The code is written in Hi-Tech C. After I compiled, there is a .hex file.
I used the CCS ICD-40 and its GUI software to program it into the CHIP
and it will never work. It seemed program OK, but when the board will
never work.
rwyoung
PostPosted: Mon Aug 22, 2005 10:13 am     Reply with quote
Check the fuses being programmed. Things like oscillator type, power-up timer, brownout etc.
Also fuses and address 0 as related to the debugger.
Can you read back the program from the PIC. I don't mean the verify that occurs right after programming. I mean manually reading back and verifying.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
