structure array size limit
eaton
PostPosted: Sun Aug 14, 2005 5:53 am     Reply with quote
I have a structure that uses 18 bytes. I need an array of these. if the array size is greater than 14 it doesn't work. A 15 element array takes 270 bytes. 14 elements takes 252. Is there an 8-bit cut-off point in the size of a variable? Using compiler ver 3.169 and PIC18F252.
Mark
PostPosted: Sun Aug 14, 2005 8:19 am     Reply with quote
Read these for info on the problem that you are seeing and a possible work around:
http://www.ccsinfo.com/forum/viewtopic.php?t=21004&highlight=maximum+array+size
http://www.ccsinfo.com/forum/viewtopic.php?t=5598&highlight=maximum+array+size
Also:
It seems that the real problem is with bank addressing so indirect addressing should be okay. If you reserve that memory area and then assign a pointer to that location I believe that you might be able to access the data just fine. I'll let you be the one to try it out.
PostPosted: Mon Aug 15, 2005 2:56 am     Reply with quote
There was a fix for this type of problem in 3.189. You may be able to bodge round it as Mark describes, but the current releases seem to handle larger sizes OK.
