I am trying to migrate from a PIC18F6722 running at 20MHz (HS) to a PIC18F6722 running at 40MHz (10MHz H4). The hardware is identical except for the crystal and PIC.
ICD Control program is version 2.30
My ICD-U40 works fine with the 6720 chip but is very intermittent with the 6722. I have just managed to program a 6722 but pressing run causes the following error
Could not release reset: Could not detect target chip
Test target then reports Unknown PIC18 ID 1400
To recover I have to shut down the control program.
Any Ideas?
Nandini
Posted: Wed Jul 13, 2005 12:47 pm
Try using the latest ICD softare from the web and email tech support it is still an issue.
sseidman
Re: Problems with ICD-U40 and PIC18F6722
Posted: Wed Jul 13, 2005 1:04 pm
Any Ideas?
I think I had a similar problem once, and IIRC, the chip needed to be physically powered down and powered back up after the fuse was changed.
