BradleyEE
Joined: 16 Dec 2004 Posts: 3 Location: Minneapolis, MN
setup_oscillator() |
Posted: Wed Jun 29, 2005 11:01 am |
I'm using the latest compiler (3.226), but the help file doesn't include setup_oscillator. I'm looking at the 18F8490.h device file at the oscillator section and am wondering which bits some of these constants set/clear.
////////////////////////////////////////////////////////////////// INTERNAL RC
// Constants used in setup_oscillator() are:
// First param:
#define OSC_31KHZ 0
#define OSC_125KHZ 0x10
#define OSC_250KHZ 0x20
#define OSC_500KHZ 0x30
#define OSC_1MHZ 0x40
#define OSC_2MHZ 0x50
#define OSC_4MHZ 0x60
#define OSC_8MHZ 0x70
// The following may be OR'ed in with the above using |
#define OSC_TIMER1 1
#define OSC_INTRC 2
#define OSC_NORMAL 0
#define OSC_IDLE_MODE 0x80
#define OSC_31250 0x80
#define OSC_PLL_ON 0x40
#define OSC_PLL_OFF 0
// A second optional parameter may be used with this part to fine
// tune the speed (signed int,0-31)
// Result may be (ignore all other bits)
#define OSC_STATE_STABLE 4
#define OSC_STATE_EXT_RUNNING 8
Specifically, the OSC_IDLE_MODE option and the OSC_31250 option.
I am using this line:
setup_oscillator(OSC_1MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
This was produced by the wizard. I would assume that OSC_31250 selects between the prescaled internal 8MHz clock and the RC used by the WDT and has no effect when running at 1MHz. But this line of code writes 0xC2 to the OSCCON register which means that idle mode is entered with the SLEEP instruction.
The LST file includes:
.................... setup_oscillator(OSC_1MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
00E0: MOVLW C2
00E2: MOVWF FD3
Am I reading this all correctly? I'll admit this is my first use of an 18F-series part, so I'm still coming up to speed.
What I'm after is to use the internal RC oscillator at 1MHz (for now), no PLL, and no idle mode. I currently have #FUSES INTRC_IO set as well.
Bradley |
theMagni
Posted: Wed Jun 29, 2005 12:47 pm |
To be honest, I dislike the setup_oscillator() function. I just have OSC_CON defined and have the settings I want #defined. That way, I know exactly what it's doing. This is on a 16F88 / 18F2420. (It's great how that works out.)
#define FOUR_MHz 0b01100010
#define THIRTYTWO_kHz 0b00000010
OSC_CON = FOUR_MHz;
OSC_CON = THIRTYTWO_kHz; |
Posted: Wed Jun 29, 2005 1:58 pm |
Quote: | I'm using the latest compiler (3.226), but the help file doesn't include setup_oscillator(). |
CCS has two help files in the c:\Program Files\Picc folder:
The real one is CCSC.CHM and you can identify it in Windows Explorer
by its file type, which is "Compiled HTML Help File".
They've also got an older one, CCSC.HLP in that folder, which doesn't
have setup_oscillator() in it.
Quote: | I'm looking at the 18F8490.h device file at the oscillator section
and am wondering which bits some of these constants set/clear. |
The constant definitions are screwed up. I think they really should
look like this:
Code: | // Constants used in setup_oscillator() are:
// First param:
#define OSC_31KHZ 0
#define OSC_INTRC 2
// to fine tune the speed (signed int,0-31)
// The following may be OR'ed in with the fine-tune bits
// of the 2nd parameter by using |
#define OSC_STATE_EXT_RUNNING 8 |
Also, CCS implies that setup_oscillator() will return a value.
I tried to have the function return a value with a 16F88 (which
does have the "frequency stable" bit) and the compiler gave
me an error. So the "Result" part of the definitions above
are not really useful. |
BradleyEE
Posted: Wed Jun 29, 2005 5:04 pm |
PCM programmer wrote: |
// First param:
#define OSC_31KHZ 0
#define OSC_INTRC 2
Good call. The OSC_31250 is the same as the OSC_IDLE_MODE, which is why that was being set. I suppose I should send a bug report via email about this. Got rid of the OSC_31250 and the OSC_PLL_OFF (it's zero anyway) and now the assembly for that line is coming out to what I would expect.
Bradley |
BradleyEE
Posted: Wed Jun 29, 2005 5:07 pm |
theMagni wrote: | To be honest, I dislike the setup_oscillator() function. I just have OSC_CON defined and have the settings I want #defined. That way, I know exactly what it's doing. This is on a 16F88 / 18F2420. (It's great how that works out.)
OSC_CON = FOUR_MHz;
Yes, I'm leaning towards doing the same thing. I have some some reservations because it seems that some directives and functions will occasionally interact.
The next question I'm going to have is going to be about setup_lcd(), but perhaps I'll just roll my own configuration routines so that I know that (and how) they work.
Bradley |
Posted: Wed Jun 29, 2005 5:13 pm |
The problem is not really that the constants are the same,
its rather that CCS didn't make it clear that some of the
constants are to be used with the 1st parameter and
others are only to be used with the 2nd parameter of
the setup_oscillator() function. |
