cannot debug using PIC18LF2620
dax
PostPosted: Tue Jun 14, 2005 10:44 am     Reply with quote
Hi, i've the 18LF2620, using ICD-U40 and programing PCW CCS 3.224. I have the same problem related in others topics: When I try to debug it loads the program, but, it says the famous: "Could not start target: The target was not halted after reset Check the target oscilator and MCLR" The header of my program is
#include <18F2620.h>
#device ICD=TRUE
#fuses H4,NOIESO,NOBROWNOUT,NOWDT,NOPUT,STVREN,NOLVP,NOFCMEN,NOXINST,NOPBADEN,MCLR
#use delay (clock=32000000)
I ve tried what its said in other topics but I cant find whats grong. The PIC its connected only to VCC,GND, and the ICD, i have not external resonator. Its maybe that? All sugestions are welcome!
Tom-H-PIC
18F2620 ICD-U reset/halt oscillator problem
PostPosted: Sat Jun 18, 2005 6:01 am     Reply with quote
Look at my reply on this post and see if that helps.
Tom
http://www.ccsinfo.com/forum/viewtopic.php?t=22020&highlight=18f2620+icd
dax
solved
PostPosted: Sat Jun 18, 2005 4:14 pm     Reply with quote
Thanks for your reply, at last I tried to do everything posted in other topics-> put the oscilator line at the end, disable the put fuse, and at last fix a little hardware problem that i had with my oscilator. Finally with this three fixed it works!
