ICD control working - Debugger not
mcurtis
PostPosted: Wed May 25, 2005 7:44 am     Reply with quote
All was good, untill i updated ICDU software (April 26th download) . Now the debugger gives me "can't detect target chip", however if I use the ICD control program, all works fine(passes all tests,and downloads). Seems if one works, the other should, however I'm just a hobbiest, so not all that clear on how they differ. Using ver 3.42 ide, 1.87 compilers, v2.30 icd control prrogram, 1.39 icd firmware, and ICDU40. Tried rolling back to previuos versions, but didn't help. Just to keep progress moving forward I'm using the ICD program, but it's not as much fun.
Maynard
mcurtis
PostPosted: Thu May 26, 2005 7:36 am     Reply with quote
Found a solution, but not an answer. Switched to a 18F452 from the 16F877 and debugger started working again. I had been running in fast mode (-5v option -Advanced tab on icd control). on start up with 18F452, got a warning this may cause problems. Tried turning it off and went back to 16F877, but still did not work. Please keep me posted if ccs responds.
-maynard
smashHIT
View user's profile Send private message ICQ Number
PostPosted: Sun May 29, 2005 2:42 pm     Reply with quote
Had the same problem, and asked CCS what to do:
Sir,
Try renaming the devices.dat to deviceso.dat and the devicesp.dat to devices.dat in the compiler directory.
CCS Tech Support
That worked like a charm!
seven
PostPosted: Mon May 30, 2005 1:39 am     Reply with quote
i do not have the file "devices.dat".
Is it available just with the lastest version? cause i'm running with the 3.222 version
mcurtis
PostPosted: Tue May 31, 2005 7:05 am     Reply with quote
Worked for me as well. While testing, I noticed the 18F452 downloads much faster than the 16F877. Do different chips have different ICSP download speeds, or is this a CCS debugger issue.
scanpa
Have same problem
PostPosted: Tue Jun 07, 2005 6:20 am     Reply with quote
Hi Guys,
I have the same problem after installation of rel 3.225: ICD is working stand alone but not as debugger.
Making a roll back to previous 3.224 all is ok.
CCS support can help us ?
