darren logan Guest
| Optimising tricks of the trade ! |
Posted: Sun Feb 02, 2003 5:53 am |
Im fairly new to PIC C, but have just completed my first project involving many of the more advanced features of a PIC (such as timer and UART interrupts).
My budget was to used a PIC16F870 and several times during the project I was faced with the dreaded OUT OF ROM message.
When this happened, I would go back through my code and check to see if I could cut down or optimise to trim down the code size, and sure enough I did.
I learnt several tricks along the way to save space and Im sure it would be of benefit to share mine, and you share yours. Here are a couple that made a big difference for me...
(Note that these may not apply to you, depending on your setup but I should imagine they will come in handy at some point!):
Instead of using:
output_low(whatever)
Use:
bit_clear(*x,y)
(also use bit_set instead of output_high)
Instead of using:
delay_ms(xxx)
Use:
for(i=0;i
(I.e., use a for/loop. However a for loop instead of delay_us on the other hand does not save space)
Please post your handy tips !
Cheers,
Darren
___________________________
Original Post ID: 11198 |
mark r. hahn Guest
| Re: Optimising tricks of the trade ! |
Posted: Sun Feb 02, 2003 5:47 pm |
:=Hello,
--- snip ---
:=Please post your handy tips !
:=Cheers,
:=Darren
I wrote a review of the CCS PCM compiler a few years back. I included several tips on how to make your programs smaller. Most of what I wrote then still holds. You might wish to check out my web page: <a href="http://home.hvc.rr.com/mhahn/HahnTronix.html" TARGET="_blank">http://home.hvc.rr.com/mhahn/HahnTronix.html</a>
Happy crunching,
Mark Hahn
Original Post ID: 11214 |
Darren Logan Guest
Posted: Wed Feb 26, 2003 6:41 pm |
My program contained several write_eeprom and read_eeprom commands.
I replaced them with my own read/writes thus:
void writetoeeprom(int addr, int data) {
write_eeprom(addr,data);
int readfromeeprom(int addr) {
return(read_eeprom(addr));
This made a significant difference.
Regards,
Darren
Original Post ID: 12149 |
