Run Time Error with 877A
Vince McCarroll
PostPosted: Tue Apr 12, 2005 1:27 pm     Reply with quote
Can someone explain why I get an error message when I try to run a program on an 877A and I do not get one when I run the program on an
877. Your response would be greatly appriciated
Haplo
PostPosted: Wed Apr 13, 2005 1:46 am     Reply with quote
You have to give us more details. You are getting the run-time error in what? What header are you using? What programmer? What debugger?
Vince McCarroll
877A Run Time Error
PostPosted: Wed Apr 13, 2005 10:37 am     Reply with quote
Hi All
The problem has been solved. The version compiler installed on the system does not include 877A in the PICChip Lists. A newer version of the compiler has been installed.
Thanks again for your responses
