		| Author | Message |
		| sudarsan
				| pic16f877a and t6963 glcd c code  tested and working |
				|  Posted: Thu Nov 08, 2012 1:04 am |   |
				|  	  | Code: |  	  | /* main file */
 /* copy this code into notepad and save as (urfilename).c  */
 #include <16F877a.h>
 #Fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
 #include "t6963.h"
 #include "t6963.c"
 GDispInit();                         //T6963C display initialization
 GDispSetMode(XOR_MODE|INT_CG_MODE);  //Exclusive OR mode, internal CG character RAM
 GDispSetMode(TEXT_GRH_ON);           //Text ON, Graphics ON
 GDispClrTxt();                       //Clear the text area
 GDispClrGrh();                       //Clear the graphics area (dot-by-dot!)
 GDispGoto(0,0);
 GDispChar(0x85);
		| sudarsan
				| t6963.c file |
				|  Posted: Thu Nov 08, 2012 1:07 am |   |
				|  	  | Code: |  	  | /* t6963.c file */
 #include "font5x7.h"      //custom-defined 5x7 font, for GDispPixFontAt(...)
 *                              LOCAL CONSTANTS
 #define CURSOR_PTR_SET      0x21    //Cursor Pointer Set
 #define OFFSET_REG_SET      0x22    //Set Offset Command
 #define ADDR_PTR_SET        0x24    //Set Address Pointer Command
 #define TEXT_HOME_SET       0x40    //Text Home Address Set: Data = low, high addr
 #define TEXT_AREA_SET       0x41    //Text Area Set: Data = columns, 0
 #define GRAPH_HOME_SET      0x42    //Graphics Home address Set: Data = low, high addr
 #define GRAPH_AREA_SET      0x43    //Graphics Area Set: Data = columns, 0
 #define SCREEN_PEEK         0xE0    //Read data from screen command
 #define SCREEN_COPY         0xE8    //Screen Copy
 #define AUTO_WR_ON            0xB0
 #define DATA_AUTO_RD          0xB1
 #define AUTO_WR_OFF           0xB2
 #define DATA_WR_INC         0xC0      // Data write and increment addrespointer
 #define DATA_RD_INC         0xC1      // Data read and increment  addrespointer
 #define DATA_WR_DEC         0xC2      // Data write and decrement addrespointer
 #define DATA_RD_DEC         0xC3      // Data read and decrement  addrespointer
 #define DATA_WR             0xC4      // Data write - no addr change
 #define DATA_RD             0xC5      // Data read  - no addr change
 *                           LOCAL FUNCTION PROTOTYPES
 static void GDispCmdAddrSend(unsigned int16 Addr, unsigned char cmd);
 *                                     SEND ADDRESS COMMAND
 * Description : This function sends screen address with a command to the LCD screen
 * Arguments   : 'Addr'  is the screen address to send
 *            'cmd'   is the command
 * Returns     : none
 * Notes        : Most often a graphic LCD needs a screen address for command setup.
 *            Example, set Graph Home Address is the command GRAPH_HOME_SET (0x42), at the ram address
 *            GRH_HOME_ADDR (0x0200), say.
 unsigned int8 c;
 c = Addr&0x00FF;
 GDispDataWr(c);      //Send LSB of 'Addr' first
 c = Addr >> 8;
 GDispDataWr(c);      //Send MSB of 'Addr' afterwards
 GDispCmdSend(cmd);
 *                                     DISPLAY DRIVER INITIALIZATION
 * Description : This function initializes the display driver
 * Arguments   : none
 * Returns     : none
 * Notes        :
 void GDispInit(void)
 //Reset the LCD module and perform a hardware port init
 GDispInitPort();
 //Set Text Home address to TEXT_HOME_ADDR
 GDispCmdAddrSend(TEXT_HOME_ADDR,TEXT_HOME_SET);
 //Set Graph Home address to GRH_HOME_ADDR
 GDispCmdAddrSend(GRH_HOME_ADDR,GRAPH_HOME_SET);
 //Set Text Area to COLUMN column mode
 GDispCmdAddrSend(COLUMN,TEXT_AREA_SET);
 //Set Graph Area to COLUMN column mode
 GDispCmdAddrSend(COLUMN,GRAPH_AREA_SET);
 //Set Offset register to 0x0002, CG Ram start address = $1400 (CG_HOME_ADDR)
 //first character code $80 for CG Ram
 GDispCmdAddrSend(0x0002,OFFSET_REG_SET);
 *                               SET MODE FOR DISPLAY/MODE/CURSOR/TEXT_ATTRIBUTE
 * Description : This function sets mode
 * Arguments   : 'mode'   , refer to mode available in t6963.h, MODE Section, CURSOR MODE, TEXT ATTRI
 * Returns     : none
 * Notes        :
 void GDispSetMode(unsigned int8 mode)
 GDispCmdSend(mode);
 *                                        CLEAR TEXT SCREEN
 * Description : This function clears the text clear in font mode
 * Arguments   : none
 * Returns     : none
 * Notes        :
 void GDispClrTxt(void)
 unsigned int16 row;
 unsigned int16 col;
 //Set address pointer to address (TEXT_HOME_ADDR)
 GDispCmdAddrSend(TEXT_HOME_ADDR,ADDR_PTR_SET);
 //Set Auto Write ON
 GDispCmdSend(AUTO_WR_ON);
 //row runs from 0 ... (MAX_ROW_PIXEL/8 -1), in form of a cell of (FontSize x 8) bits
 for(row=0; row < MAX_ROW_PIXEL/8; row++)
 {      //write blank to clear screen the first page only, col = 0...(COLUMN-1)
 for(col=0; col < COLUMN; col++)
 GDispAutoDataWr(0x00);
 //Set Auto Write OFF
 GDispCmdSend(AUTO_WR_OFF);
 *                                     CLEAR THE GRAPHIC AREA
 * Description : This function clears the graphic area pixel by pixel
 * Arguments   : none
 * Returns     : none
 * Notes        :
 void GDispClrGrh(void)
 unsigned int16 row;
 unsigned int16 col;
 //Set address pointer to address (GRH_HOME_ADDR)
 GDispCmdAddrSend(GRH_HOME_ADDR, ADDR_PTR_SET);
 //row runs from 0 ... (MAX_ROW_PIXEL-1), in form of a byte size of (FontSize x 1) bits
 for(row=0; row < MAX_ROW_PIXEL; row++)
 for (col=0; col < COLUMN; col++)
 GDispCmdSend(AUTO_WR_OFF);   //Set Auto Write OFF
 *                                       GOTO A POSITION (row, col)
 * Description : This function sets the screen address pointer to a position row, col
 * Arguments   : 'row'   row = 0...(MAX_ROW_PIXEL/8 - 1), the cell number in 8 bits height
 *            'col'   col = 0...(COLUMN-1), is the column position in font width (6/8 font)
 * Returns     : none
 * Notes        :
 void GDispGoto(unsigned int16 row, unsigned int16 col)
 unsigned int16 addr;
 addr = row*COLUMN + col + TEXT_HOME_ADDR;
 GDispCmdAddrSend(addr,ADDR_PTR_SET);                     //Set address pointer
 *                     DISPLAY A CHARACTER AT THE CURRENT SCREEN ADDRESS POINTER
 * Description : This function is used to display a single character on the display device at row, col
 *            col, row should have been set by GDispGoto(row, col) before. AUTO ADDRESS POINTER INC!
 * Arguments   :   'c'     is the ASCII character to write
 * Returns     : none
 * Notes        : This function gets around the problem that pointers cannot be created to constant string
 *            in PCM. Referring to CCS Reference Manual (page 67), a function that has one CHAR
 *            parameter will accept a constant string where it is called. PCM will generate a loop
 *            that will call the function once for each character in the string.
 *            Example :
 *               GDispGoto(5,5);
 *               GDispChar("Hello there!");
 void GDispChar(unsigned char c)
 GDispDataWr(c - 0x20);               //Adjust standard ASCII to T6963 ASCII
 GDispCmdSend(DATA_WR_INC);            //Address pointer increment ON
 *                              DISPLAY A CHARACTER AT A POSITION (row, col)
 * Description : This function is used to display a single character on the display device, address
 *            auto increment OFF!
 * Arguments   : 'row'   row = 0...(MAX_ROW_PIXEL/8 - 1), the row pos of the cursor (MAX_ROW_PIXEL/8-1)
 *            'c'     is the ASCII character to write
 * Returns     : none
 * Notes        : COLUMN constant determines the number of page, can be > physical size of the LCD
 void GDispCharAt(unsigned int16 row, unsigned int16 col, unsigned char c )
 GDispGoto(row, col);
 GDispCmdSend(DATA_WR);
 *                                     SET CURSOR AT A POSITION
 * Description : This function sets cursor at a position (row, col), of certain mode & type
 * Arguments   : 'mode' is the mode of cursor. It should be bitwise OR with a TEXT / GRAPH mode to work
 *                   mode =    TEXT_GRH_ON|CURSOR_BLINK_ON
 *                        TEXT_ON|CURSOR_ON_BLINK_OFF....
 *                        TEXT_ON, without bitwise OR any cursor mode only will clear cursor
 *            'row'  is the MSB of screen address, the row position of the cursor
 *            'col'  is the LSB of the screen address, the column position of the cursor
 *            'type' is cursor type
 *                  type = LINE_1_CURSOR / LINE_8_CURSOR
 * Returns     : none
 * Notes        : Cursor address is not like text address pointer. Cannot use GDispGoto(row,col).
 void GDispSetCursor(unsigned int8 mode, unsigned int16 row, unsigned int16 col, unsigned int8 type)
 addr = row << 8;
 addr = addr|(col&0x00FF);
 GDispCmdAddrSend(addr, ADDR_PTR_SET);
 GDispCmdSend(CURSOR_PTR_SET);        //Set cursor position
 GDispCmdSend(mode);
 GDispCmdSend(type);             //cursor mode
 *                                     SET PIXEL AT X, Y POSITION
 * Description : This function sets a pixel with color = BLACK / WHITE (defined in t6963.h)
 * Arguments   : 'X'    0....MAX_COL_PIXEL is matrix position in horizontal direction
 *            'Y     0....MAX_ROW_PIXEL is matrix position in vertical direction
 *            'color'  sets BLACK / WHITE standing for pixel ON/OFF
 * Returns     : none
 * Notes        :
 void GDispSetPixel(unsigned int16 X, unsigned int16 Y, unsigned int8 color)
 unsigned int16 row, col;
 unsigned char cmd;
 row = Y;
 col = X/8;
 addr = row*COLUMN + col + GRH_HOME_ADDR;
 if (color == BLACK)
 cmd = (0b11111000)|(8- 1 -(X%8));
 cmd = (0b11110000)|(8- 1 -(X%8));
 GDispCmdSend(cmd);
 void glcd_3Dbox(int16 x,int16 y,int16 width, int16 height, int depth, int1 color)
 int16 i,j;
 for(i=x;i<=x+width;i++)
 GDispSetPixel(i,y,1);
 GDispSetPixel(i,y+height,1);
 for(i=y;i<=y+height;i++)
 GDispSetPixel(x,i,1);
 GDispSetPixel(x+width,i,1);
 for(j=1;j<=depth;j++)
 for(i=y+j;i<=y+height+j;i++)
 GDispSetPixel(x-j,i,1);
 for(i=x-j;i<=(x-j+width);i++)
 GDispSetPixel(i,y+height+j,color);
 *                               SET TEXT ATTRIBUTE (NOT COMPLETE DEBUG)
 * Description : This function sets / clears text attribute mode
 *            'mode'  =    ATTR_REVERSE, ATTR_INHIBIT, ATTR_BLINK_REVERSE, ATTR_BLINK_INHIBIT...
 *                     (see TEXT ATTRIBUTE MODE in t6963.h for available mode)
 * Returns     : none
 * Notes        : After function call to GDispSetAttrb(row,col,ATTR_BLINK_REVERSE),
 *            should use GDispSetAttrib(row,col, ATTR_NORMAL) before using graphic area again to avoid
 *            graphic area data write error!
 void GDispSetAttrb(unsigned int16 row, unsigned int16 col, unsigned int8 mode)
 GDispAutoDataWr(mode);
 GDispCmdSend(TEXT_ATTR_MODE);
 GDispCmdSend(TEXT_GRH_ON);
 *                                  SET CUSTOM DEFINED CHARACTER TO CG RAM
 * Description : This function assigns a custom created pattern of 8 BYTE with an id number
 * Arguments   : 'id'   is the identifier for the pattern created. Range of 'id' is 0...127 for T6963.
 *            'pat'    is a pointer to an 8 BYTE array containing the dot pattern
 * Returns     : none
 * Notes        : Pointers cannot be created to constant arrays in PCM. Thus, a global CGBuffer[]'s created
 *            in t6963.h to store a constant array to RAM space.
 *            Code Example   ::
 *            char i;
 *            const char CUSTOM_PAT[8] = {0x00, 0x23, 0x45, 0x56, 0x89, 0xAB, 0xFF, 0xEE};
 *            for(i=0;i<8;i++) CGBuffer[i] = CUSTOM_PAT[i]   //assign CUSTOM_PAT[] to CGBuffer[]
 *            GDispDefCGChar(0, &CGBuffer[0]);            //create a pattern in CG RAM with id '0'
 void GDispDefCGChar(unsigned int8 id, unsigned char *pat)
 unsigned int8 i;
 GDispCmdAddrSend(CG_HOME_ADDR+(unsigned int16)id*8, ADDR_PTR_SET);
 for(i=0; i<8; i++)
 GDispDataWr(*pat++);
 *                DISPLAY AN EXTERNAL CG CHARACTER AT THE CURRENT SCREEN ADDRESS POINTER
 * Description : This function shows a pre-defined CG RAM character at the current screen address pointer
 * Returns     : none
 * Notes        :
 void GDispCGChar(unsigned int8 id)
 GDispDataWr(0x80 + id);               //Adjust standard ASCII to T6963 ASCII
 GDispCmdSend(DATA_WR_INC);            //'0x80 + id's range 0 to 255, good for GDispDataWr(char)
 *                         DISPLAY AN EXTERNAL CG CHARACTER AT ROW, COL
 * Description : This function shows a pre-defined CG RAM character at (row, col) coordinates
 * Returns     : none
 * Notes        :
 void GDispCGCharAt(unsigned int16 row, unsigned int16 col, unsigned int8 id)
 GDispGoto(row,col);
 GDispCGChar(id);
 *                            DISPLAY A BLANK ICON OF 32x32 MATRIX AT ROW, COL
 * Description : This function clears the 32x32 ICON at (row, col) coordinates
 * Returns     : none
 * Notes        :
 void GDispBlkIcon32X32At(unsigned int16 row, unsigned int16 col)
 unsigned int16 row_cnt, col_cnt;
 for(row_cnt = row; row_cnt < (row+4); row_cnt++)
 for(col_cnt = col; col_cnt < (col+4); col_cnt++)
 GDispCharAt(row_cnt, col_cnt, ' ');
 *                  CONVERT A STRING TO PIXEL DATA AND DISPLAY AT X,Y IN GRAPHIC MODE
 * Description : This function outputs a string in graphic mode from a char* textptr pointer
 *            'textptr'   pointer to the string to write
 *            'size'      should be non-zero, 1 = 5x7, 2 = 10x14, ..., basically "enlarge" the font
 *                     defined under font5x7.h.
 *            'color'      BLACK / WHITE
 * Returns     : none
 * Notes        : Copyright (c) 2004 Sentinel Systems Corporation
 *            Example, declare a string
 *            char str[] = "Hello World!";
 *            main()
 *               GDispPixFontAt(0,20,&str[0],2,BLACK); //Display the "Hello World!" string starting
 *                                            //at (x,y)=(0,20), in size font size 2 (10x14)
 *                                            //color in black
 void GDispPixFontAt(unsigned int16 X, unsigned int16 Y, unsigned char* textptr, unsigned char size, int1 color)
 const BYTE bytes_per_char = 5;
 int i, j, k, l, m;                         // Loop counters
 BYTE pixelData[bytes_per_char];             // Stores character data
 for(i=0; textptr[i] != '\0'; ++i, ++X)          // Loop through the passed string
 if(textptr[i] < 'S')                   // Checks if the letter is in the first or second array
 memcpy(pixelData, FONT1[textptr[i]-' '], bytes_per_char);
 else if(textptr[i] <= '~')                // Check if the letter is in the second array
 memcpy(pixelData, FONT2[textptr[i]-'S'], bytes_per_char);
 else                               // Default to space if character out of range
 memcpy(pixelData, FONT1[0], bytes_per_char);
 if(X+5*size >= MAX_COL_PIXEL)             // Performs character wrapping
 X = 0;                            // Set X at far left position
 Y += 7*size + 1;                   // Set Y at next position down
 for(j=0; j<bytes_per_char; ++j, X+=size)    // 5 bytes per character
 for(k=0; k<7*size; ++k)             // Loop through the vertical pixels
 if(bit_test(pixelData[j], k))          // Check if the pixel should be set
 for(l=0; l<size; ++l)             // The next two loops change the character's size
 for(m=0; m<size; ++m)
 {                         // Draws the pixel
 GDispSetPixel(X+m, Y+k*size+l, color);
 } //for(i = 0; textptr[i] != '\0';...)
 *                                      I/O PORT INITIALIZATION
 * Description : This initializes the I/O ports used by the display driver
 * Arguments   : none
 * Returns     : none
 * Notes        :
 void GDispInitPort(void)
 LCD_RST = 0;
 LCD_CD = 1;
 LCD_CE = 1;
 LCD_RD = 1;
 LCD_WR = 1;
 LCD_DATA = 0x00;
 //Set all control line as output
 LCD_CE_TRIS = 0;
 LCD_RD_TRIS = 0;
 LCD_CD_TRIS = 0;
 LCD_WR_TRIS = 0;
 LCD_RST_TRIS = 0;
 LCD_DATA_TRIS = 0x00;
 //Turn on LCD module after reset
 #asm
 nop
 #endasm
 LCD_RST=1;
 *                                          BUSY CHECK
 * Description : This function checks command execution capability, & data read/write capability
 * Arguments   : none
 * Returns     : none
 * Notes        :
 void GDispBusyChk(void)
 GDispCmdRd;
 GDispChipEn;
 #asm
 nop
 #endasm
 while (!STA0)         // Busy Check here
 while (!STA1)
 GDispChipDi;         //Chip disable to finish
 *                                       AUTO MODE DATA WRITE CHECK
 * Description : This function checks auto mode data write capability
 * Arguments   : none
 * Returns     : none
 * Notes        :
 void GDispAutoWrChk(void)
 GDispCmdRd;
 GDispChipEn;
 #asm
 nop
 #endasm
 while(!STA3)
 GDispChipDi;
 *                                          WRITE DATA TO LCD MODULE
 * Description : This function sends a single data byte to the display device
 * Arguments   : 'data' is the BYTE to send to the display device
 * Returns     : none
 * Notes        :
 void GDispDataWr(unsigned char data)
 GDispBusyChk();             // Wait for LCD to be ready
 LCD_DATA = data;               // Data write
 #asm
 nop
 #endasm
 GDispDatWr;
 GDispChipEn;
 #asm
 nop                     //delay one cycle for port stablize
 #endasm
 GDispChipDi;
 *                        WRITE DATA TO LCD MODULE, SCREEN ADRESS AUTO-INCREMENTED
 * Description : Send a single data byte to the screen with screen address auto'ly incremented
 * Returns     : none
 * Notes        :
 void GDispAutoDataWr(unsigned char data)
 GDispAutoWrChk();             // Auto write mode check
 #asm
 nop
 #endasm
 GDispDatWr;
 GDispChipEn;
 #asm
 #endasm
 GDispChipDi;
 *                                       WRITE COMMAND TO LCD MODULE
 * Description : This function sends a single byte as command to the display device
 * Arguments   : 'cmd' is the COMMAND BYTE to send to the display device
 * Returns     : none
 * Notes        :
 void GDispCmdSend(unsigned char cmd)
 LCD_DATA = cmd;
 GDispCmdWr;
 GDispChipEn;
 #asm
 nop
 #endasm
 GDispChipDi;
		| sudarsan
				| t6963.h file |
				|  Posted: Thu Nov 08, 2012 1:09 am |   |
				|  	  | Code: |  	  | /* ***********************************************************************************************
 *                              PORT DEFINITION
 #byte   PORTA   =   0x05
 #byte   TRISA   =   0x85
 #bit   PORTA0   =   PORTA.0
 #bit   PORTA1   =   PORTA.1
 #bit   PORTA2   =   PORTA.2
 #bit   PORTA3   =   PORTA.3
 #bit   PORTA4   =   PORTA.4
 #bit   PORTA5   =   PORTA.5
 #bit   TRISA0   =   TRISA.0
 #bit   TRISA1   =   TRISA.1
 #bit   TRISA2   =   TRISA.2
 #bit   TRISA3   =   TRISA.3
 #bit   TRISA4   =   TRISA.4
 #bit   TRISA5   =   TRISA.5
 #byte   PORTB   =   0x06
 #byte   TRISB   =   0x86
 #bit   PORTB0   =   PORTB.0
 #bit   PORTB1   =   PORTB.1
 #bit   PORTB2   =   PORTB.2
 #bit   PORTB3   =   PORTB.3
 #bit   PORTB4   =   PORTB.4
 #bit   PORTB5   =   PORTB.5
 #bit   PORTB6   =   PORTB.6
 #bit   PORTB7   =   PORTB.7
 #bit   TRISB0   =   TRISB.0
 #bit   TRISB1   =   TRISB.1
 #bit   TRISB2   =   TRISB.2
 #bit   TRISB3   =   TRISB.3
 #bit   TRISB4   =   TRISB.4
 #bit   TRISB5   =   TRISB.5
 #bit   TRISB6   =   TRISB.6
 #bit   TRISB7   =   TRISB.7
 #byte   PORTC   =   0x07
 #byte   TRISC   =   0x87
 #bit   PORTC0   =   PORTC.0
 #bit   PORTC1   =   PORTC.1
 #bit   PORTC2   =   PORTC.2
 #bit   PORTC3   =   PORTC.3
 #bit   PORTC4   =   PORTC.4
 #bit   PORTC5   =   PORTC.5
 #bit   PORTC6   =   PORTC.6
 #bit   PORTC7   =   PORTC.7
 #bit   TRISC0   =   TRISC.0
 #bit   TRISC1   =   TRISC.1
 #bit   TRISC2   =   TRISC.2
 #bit   TRISC3   =   TRISC.3
 #bit   TRISC4   =   TRISC.4
 #bit   TRISC5   =   TRISC.5
 #bit   TRISC6   =   TRISC.6
 #bit   TRISC7   =   TRISC.7
 #byte   PORTD   =   0x08
 #byte   TRISD   =   0x88
 #bit   PORTD0   =   PORTD.0
 #bit   PORTD1   =   PORTD.1
 #bit   PORTD2   =   PORTD.2
 #bit   PORTD3   =   PORTD.3
 #bit   PORTD4   =   PORTD.4
 #bit   PORTD5   =   PORTD.5
 #bit   PORTD6   =   PORTD.6
 #bit   PORTD7   =   PORTD.7
 #bit   TRISD0   =   TRISD.0
 #bit   TRISD1   =   TRISD.1
 #bit   TRISD2   =   TRISD.2
 #bit   TRISD3   =   TRISD.3
 #bit   TRISD4   =   TRISD.4
 #bit   TRISD5   =   TRISD.5
 #bit   TRISD6   =   TRISD.6
 #bit   TRISD7   =   TRISD.7
 #byte    PORTE   =   0x09
 #byte   TRISE   =   0x89
 #bit   PORTE0   =   PORTE.0
 #bit   PORTE1   =   PORTE.1
 #bit   PORTE2   =   PORTE.2
 #bit   TRISE0   =   TRISE.0
 #bit   TRISE1   =   TRISE.1
 #bit   TRISE2   =   TRISE.2
 //I/O port for data definition
 #ifndef T6963_H
 #define T6963_H
 #define LCD_DATA         PORTD      // LCD data port
 #define LCD_DATA_TRIS      TRISD      // LCD Data port Tris
 #define STA0            PORTD0      // Check command execution capability
 #define STA1            PORTD1      // Check data read/write capability
 #define STA2            PORTD2      // Check Auto mode data read capability
 #define STA3            PORTD3      // Check Auto mode data write capability
 #define STA5            PORTD5      // Check controller operation capability
 #define STA6            PORTD6      // Error flag. Used for screen peek and screen copy
 #define STA7            PORTD7      // Check the blink condition
 //Control pin setting
 #define LCD_CE            PORTC2      // LCD Enable control line pin number
 #define LCD_CE_TRIS        TRISC2      // LCD Enable control line direction pin #
 #define LCD_RD            PORTC1      // LCD Read control line  pin number
 #define LCD_RD_TRIS          TRISC1      // LCD Read control line direction pin #
 #define LCD_WR            PORTC0      // LCD Write control line pin number
 #define LCD_WR_TRIS          TRISC0      // LCD Write control line irection pin #
 #define LCD_CD            PORTB7      // LCD Control/data Select line
 #define LCD_CD_TRIS          TRISB7      // LCD Control/data Select line direction
 #define LCD_RST             PORTB6      // LCD RST_ line
 #define LCD_RST_TRIS      TRISB6      // LCD RST_line direction
 #endif
 *                              GLOBAL CONSTANTS
 * Note      :    The T6963 controller's RAM address space from $0000 - $FFFF, total 64kbyte RAM.
 *            It is just the RAM address set, not the actual RAM amount can be set!
 *            However, everything manufacturer may mount different amount of RAM on its
 *            module. Example, Powertip's PG12864-F has 4 kbyte RAM only.
 *            RAM space to handle 128x64 dots in 8 font = 128x64/8 = 1,024 byte.
 *            Thus, the LCD's actual visible screen area is 1 kbyte.
 *            For 8-font, 16 COLUMN,
 *            TEXT_HOME_ADDR    starts 0x0000 ending 0x01FF -> 512  bytes (for text use)?
 *            GRH_HOME_ADDR   starts 0x0200 ending 0x05FF -> 1,024 bytes ?
 *            CG_HOME_ADDR   starts 0x1400 ending 0x147F   -> 128  bytes (custom characters) ?
 #define TEXT_HOME_ADDR      0x0000
 #define GRH_HOME_ADDR       0x0200
 #define CG_HOME_ADDR      0x1400
 #define COLUMN            30      //Set column number to be e.g. 32 for 8x8 fonts, 2 pages
 #define MAX_ROW_PIXEL      64      //MAX_ROW_PIXEL the physical matrix length (y direction)
 #define MAX_COL_PIXEL      240   //MAX_COL_PIXEL the physical matrix width (x direction)
 #define ENABLE            1
 #define DISABLE            0
 #define BLACK            1
 #define WHITE            0
 *                              DISPLAY MODE
 #define DISPLAY_OFF         0x90    //0b10010000, display off
 #define CURSOR_ON_BLINK_OFF 0x92    //0b1001xx10, cursor on without blinking
 #define CURSOR_BLINK_ON     0x93    //0b1001xx11, cursor on with blinking
 #define TEXT_ON             0x94    //0b100101xx, text on, graphics off
 #define GRAPHIC_ON          0x98    //0b100110xx, text off, graphics on
 #define TEXT_GRH_ON         0x9C    //0b100111xx, text on, graphics on
 *                                 MODE
 *   Example:    OR_MODE|EXT_CG_MODE    ->    OR mode, external CG ram mode
 *            AND_MODE            ->    AND mode, internal CG ROM mode
 *      In internal CG ROM MODE (INT_CG_MODE), character codes 00h - 7Fh represent the
 *      pre-defined "internal" CG ROM characters, and codes 80h - FFh represent the
 *      users' own "external" characters. In external CG ROM MODE (EXT_CG_MODE),
 *      all 256 codes from 00h - FFh can be used to represent the users' own characters.
 #define INT_CG_MODE         0x80    //0b10000xxx, Internal CG ROM mode
 #define EXT_CG_MODE         0x88    //0b10001xxx, External CG RAM mode
 #define OR_MODE             0x80    //0b1000x000, OR mode, internal CG ROM mODE
 #define XOR_MODE            0x81    //0b1000x001, XOR mode, internal CG ROM mode
 #define AND_MODE            0x83    //0b1000x011, AND mode, internal CG ROM mode
 #define TEXT_ATTR_MODE      0x84    //0b1000x100, text attribute mode, internal CG ROM mode
 *                              CURSOR MODE
 #define LINE_8_CURSOR       0xA7    //8-line cursor mode
 #define LINE_7_CURSOR      0xA6   //7-line cursor mode
 #define LINE_6_CURSOR      0xA5   //6-line cursor mode
 #define LINE_5_CURSOR      0xA4   //5-line cursor mode
 #define LINE_4_CURSOR      0xA3   //4-line cursor mode
 #define LINE_3_CURSOR      0xA2   //3-Line cursor mode
 #define LINE_2_CURSOR      0xA1   //2-Line cursor mode
 #define LINE_1_CURSOR       0xA0    //1-Line cursor mode
 *                           TEXT ATTRIBUTE MODE
 #define ATTR_NORMAL         0x00    //Normal Display
 #define ATTR_REVERSE        0x05    //Reverse Display
 #define ATTR_INHIBIT        0x03    //Inhibit Display
 #define ATTR_BLINK          0x08    //Blinking of Normal Display
 #define ATTR_BLINK_REVERSE  0x0D    //Blinking of Reverse Display
 #define ATTR_BLINK_INHIBIT  0x0B    //Blinking of Inhibit Display
 *                             GLOBAL VARIABLES
 unsigned int8    DisplayMode;   /* Keeps state of the display mode (DISPLAY MODE)    */
 unsigned int8   Mode;         /* Keeps state of the MODE                     */
 // extern unsigned const   FontSize;      /* 6 font or 8 font                           */
 unsigned char   CGBuffer[8];   /* Buffer for custom pattern                  */
 *                           FUNCTION PROTOTYPES
 void GDispInit(void);
 void GDispSetMode(unsigned int8 mode);
 void GDispClrTxt(void);
 void GDispClrGrh(void);
 void GDispGoto(unsigned int16 row, unsigned int16 col);
 void GDispChar(unsigned char c);
 void GDispCharAt(unsigned int16 row, unsigned int16 col, unsigned char c);
 void GDispSetCursor(unsigned int8 mode, unsigned int16 row, unsigned int16 col, unsigned int8 type);
 void GDispSetPixel(unsigned int16 X, unsigned int16 Y, unsigned int8 color);
 void GDispSetAttrb(unsigned int16 row, unsigned int16 col, unsigned int8 mode);
 void GDispDefCGChar(unsigned int8 id, unsigned char *pat);
 void GDispCGChar(unsigned int8 id);
 void GDispCGCharAt(unsigned int16 row, unsigned int16 col, unsigned int8 id);
 void GDispBlkIcon32X32At(unsigned int16 row, unsigned int16 col);
 void GDispPixFontAt(unsigned int16 X, unsigned int16 Y, unsigned char* textptr, unsigned char size, int1 color);
 void glcd_3Dbox(int16 x,int16 y,int16 width, int16 height, int depth, int1 color);
 *                            HARDWARE SPECIFIC
 #define GDispChipEn      LCD_CE = 0               /* Low level Chip Enable macro          */
 #define GDispChipDi      LCD_CE = 1               /* Low level Chip Disable macro       */
 #define GDispCmdWr      LCD_DATA_TRIS = 0x00;   \
 LCD_RD = 1; LCD_CD = 1; \
 LCD_WR = 0                 /* Low level command write macro      */
 #define GDispCmdRd      LCD_DATA_TRIS = 0xFF;    \
 LCD_RD = 0; LCD_CD = 1; \
 LCD_WR = 1               /* Low level command read macro         */
 #define GDispDatWr      LCD_DATA_TRIS = 0x00;   \
 LCD_RD = 1; LCD_CD = 0; \
 LCD_WR = 0               /* Low level data write macro         */
 #define GDispDatRd      LCD_CD = 0; LCD_WR = 1      /* Low level data read macro         */
 void GDispInitPort(void);
 void GDispBusyChk(void);
 void GDispAutoWrChk(void);
 void GDispDataWr(unsigned char data);
 void GDispAutoDataWr(unsigned char data);
 void GDispCmdSend(unsigned char cmd);
		| sudarsan
				| font 5x7.h |
				|  Posted: Thu Nov 08, 2012 1:11 am |   |
				|  	  | Code: |  	  | const unsigned char FONT1[51][5] =
 0x00, 0x00, 0x00, 0x00, 0x00, // SPACE
 0x00, 0x00, 0x5F, 0x00, 0x00, // !
 0x00, 0x03, 0x00, 0x03, 0x00, // "
 0x14, 0x3E, 0x14, 0x3E, 0x14, // #
 0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
 0x43, 0x33, 0x08, 0x66, 0x61, // %
 0x36, 0x49, 0x55, 0x22, 0x50, // &
 0x00, 0x05, 0x03, 0x00, 0x00, // '
 0x00, 0x1C, 0x22, 0x41, 0x00, // (
 0x00, 0x41, 0x22, 0x1C, 0x00, // )
 0x14, 0x08, 0x3E, 0x08, 0x14, // *
 0x08, 0x08, 0x3E, 0x08, 0x08, // +
 0x00, 0x50, 0x30, 0x00, 0x00, // ,
 0x08, 0x08, 0x08, 0x08, 0x08, // -
 0x00, 0x60, 0x60, 0x00, 0x00, // .
 0x20, 0x10, 0x08, 0x04, 0x02, // /
 0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
 0x04, 0x02, 0x7F, 0x00, 0x00, // 1
 0x42, 0x61, 0x51, 0x49, 0x46, // 2
 0x22, 0x41, 0x49, 0x49, 0x36, // 3
 0x18, 0x14, 0x12, 0x7F, 0x10, // 4
 0x27, 0x45, 0x45, 0x45, 0x39, // 5
 0x3E, 0x49, 0x49, 0x49, 0x32, // 6
 0x01, 0x01, 0x71, 0x09, 0x07, // 7
 0x36, 0x49, 0x49, 0x49, 0x36, // 8
 0x26, 0x49, 0x49, 0x49, 0x3E, // 9
 0x00, 0x36, 0x36, 0x00, 0x00, // :
 0x00, 0x56, 0x36, 0x00, 0x00, // ;
 0x08, 0x14, 0x22, 0x41, 0x00, // <
 0x14, 0x14, 0x14, 0x14, 0x14, // =
 0x00, 0x41, 0x22, 0x14, 0x08, // >
 0x02, 0x01, 0x51, 0x09, 0x06, // ?
 0x3E, 0x41, 0x59, 0x55, 0x5E, // @
 0x7E, 0x09, 0x09, 0x09, 0x7E, // A
 0x7F, 0x49, 0x49, 0x49, 0x36, // B
 0x3E, 0x41, 0x41, 0x41, 0x22, // C
 0x7F, 0x41, 0x41, 0x41, 0x3E, // D
 0x7F, 0x49, 0x49, 0x49, 0x41, // E
 0x7F, 0x09, 0x09, 0x09, 0x01, // F
 0x3E, 0x41, 0x41, 0x49, 0x3A, // G
 0x7F, 0x08, 0x08, 0x08, 0x7F, // H
 0x00, 0x41, 0x7F, 0x41, 0x00, // I
 0x30, 0x40, 0x40, 0x40, 0x3F, // J
 0x7F, 0x08, 0x14, 0x22, 0x41, // K
 0x7F, 0x40, 0x40, 0x40, 0x40, // L
 0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
 0x7F, 0x02, 0x04, 0x08, 0x7F, // N
 0x3E, 0x41, 0x41, 0x41, 0x3E, // O
 0x7F, 0x09, 0x09, 0x09, 0x06, // P
 0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
 0x7F, 0x09, 0x09, 0x09, 0x76  // R
 const unsigned char FONT2[44][5]=
 0x26, 0x49, 0x49, 0x49, 0x32, // S
 0x01, 0x01, 0x7F, 0x01, 0x01, // T
 0x3F, 0x40, 0x40, 0x40, 0x3F, // U
 0x1F, 0x20, 0x40, 0x20, 0x1F, // V
 0x7F, 0x20, 0x10, 0x20, 0x7F, // W
 0x41, 0x22, 0x1C, 0x22, 0x41, // X
 0x07, 0x08, 0x70, 0x08, 0x07, // Y
 0x61, 0x51, 0x49, 0x45, 0x43, // Z
 0x00, 0x7F, 0x41, 0x00, 0x00, // [
 0x02, 0x04, 0x08, 0x10, 0x20, // \
 0x00, 0x00, 0x41, 0x7F, 0x00, // ]
 0x04, 0x02, 0x01, 0x02, 0x04, // ^
 0x40, 0x40, 0x40, 0x40, 0x40, // _
 0x00, 0x01, 0x02, 0x04, 0x00, // `
 0x20, 0x54, 0x54, 0x54, 0x78, // a
 0x7F, 0x44, 0x44, 0x44, 0x38, // b
 0x38, 0x44, 0x44, 0x44, 0x44, // c
 0x38, 0x44, 0x44, 0x44, 0x7F, // d
 0x38, 0x54, 0x54, 0x54, 0x18, // e
 0x04, 0x04, 0x7E, 0x05, 0x05, // f
 0x08, 0x54, 0x54, 0x54, 0x3C, // g
 0x7F, 0x08, 0x04, 0x04, 0x78, // h
 0x00, 0x44, 0x7D, 0x40, 0x00, // i
 0x20, 0x40, 0x44, 0x3D, 0x00, // j
 0x7F, 0x10, 0x28, 0x44, 0x00, // k
 0x00, 0x41, 0x7F, 0x40, 0x00, // l
 0x7C, 0x04, 0x78, 0x04, 0x78, // m
 0x7C, 0x08, 0x04, 0x04, 0x78, // n
 0x38, 0x44, 0x44, 0x44, 0x38, // o
 0x7C, 0x14, 0x14, 0x14, 0x08, // p
 0x08, 0x14, 0x14, 0x14, 0x7C, // q
 0x00, 0x7C, 0x08, 0x04, 0x04, // r
 0x48, 0x54, 0x54, 0x54, 0x20, // s
 0x04, 0x04, 0x3F, 0x44, 0x44, // t
 0x3C, 0x40, 0x40, 0x20, 0x7C, // u
 0x1C, 0x20, 0x40, 0x20, 0x1C, // v
 0x3C, 0x40, 0x30, 0x40, 0x3C, // w
 0x44, 0x28, 0x10, 0x28, 0x44, // x
 0x0C, 0x50, 0x50, 0x50, 0x3C, // y
 0x44, 0x64, 0x54, 0x4C, 0x44, // z
 0x00, 0x08, 0x36, 0x41, 0x41, // {
 0x00, 0x00, 0x7F, 0x00, 0x00, // |
 0x41, 0x41, 0x36, 0x08, 0x00, // }
 0x02, 0x01, 0x02, 0x04, 0x02  // ~
 | You cannot post new topics in this forum You cannot reply to topics in this forum
