fprintf(DEBUG,...) vs. printf("xxx \r\n");
valemike
PostPosted: Wed Mar 09, 2005 5:55 pm     Reply with quote
What is this "DEBUG" argument? Is this a CCS ICDU40-specific thing?
I use a MAX232 and simply do a printf("my string\r\n");
Furthermore, is there a way to avoid using so many printf() statements everywhere? Maybe i should just use sprintf and call one function where the only printf function calll resides.
-Mike
Mark
PostPosted: Wed Mar 09, 2005 6:19 pm     Reply with quote
fprintf() allows you to direct the output to a certain stream instead of printf which should do it to the last stream. DEBUG is nothing more than a stream identifier used in the #use rs232 statement.
Douglas Kennedy
PostPosted: Thu Mar 10, 2005 8:34 am     Reply with quote
#use rs232(DEBUGGER)
DEBUGGER directs the chars out via the CCS ICSP connections that go to e.g. portB and then onto the terminal window that is part of the CCS debugger IDE. An add on level shifter ( ex MAX232 ) is not needed since the data is transferred via the ICD link cable ( e.g. in the case of ICDU-40 the transfer is via USB). With that said it is no different than any other stream directive.
