ICD working with 16f876 but not with 18f2431
fire
PostPosted: Sun Sep 12, 2004 5:15 am     Reply with quote
I'm using the ICD1 from Mirochip (+CCS Firmware) together with picc.
Whenever I change the target from an PIC 16f876 to an PIC18F2431 programming (and of course also debuging) with the icd soft does not work anymore.
The target is detected, I can read the content of the flashmemory but when I try to write anything I get an vertificaton error as everything stays unchanged...
regards
fire
Nandini
PostPosted: Thu Jul 28, 2005 12:01 pm     Reply with quote
Make sure all the Vdd, AVdd, Vss, AVss pins are connected properly.
