bwgames
PIC driving an external DAC? |
Posted: Fri Aug 12, 2005 3:49 am |
Hiya,
I realise this isn't strictly PIC C related, but maybe you can shed some light.
I am using a PIC to control a DAC (MAX5712). To diagnose this problem, I've connected digital in (DIN) to the PIC (it would normally be connected to an opto-coupler), as well as SCLK and CS.
My code is as follows:
#define Fosc 40000000
#include <18F8621.h>
#DEVICE *=16 ADC=8
#include <string.h>
#include <stdio.h>
// DEFINES
#define LED PIN_C0
#define DLED PIN_C1
#define ADC_SCLK PIN_E0
#define ADC_CS PIN_E2
#define DAC_SCLK PIN_H6
#define DAC_CS PIN_H7
#define DAC_PIC_CTRL PIN_H5
// COMPILER DIRECTIVES and HARDWARE CONFIGURATION
#use delay(clock = Fosc)
#fuses EC_IO
#fuses NOOSCSEN // Oscillator System Clock Switch Disabled
#fuses NODEBUG // No Background Debugger
#fuses NOLVP // Low Voltage ICSP Disabled
#fuses NOPROTECT // No Code Protect
#fuses NOWDT // No onboard watchdog
#fuses PUT // Power Up Timer Enabled
#fuses BROWNOUT // Brown Out Reset enabled
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,parity=N,bits=8)
static short ADCFlag = 1;
static short DACFlag = 1;
static short DACCS = 1;
static short ADCCS = 1;
int trcnt = 0;
int trackk=0;
int8 MaxV[16]={0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1};
// MAIN
while(true)
if(trcnt==0){output_bit(DAC_CS,1); };
if(trcnt==4){ DACFlag=1; ADCFlag=1; output_bit(DAC_CS,0); DACCS=0; output_bit(ADC_CS,0); ADCCS=0; output_bit(DAC_SCLK,1); };
if((trcnt>=4)&&(trcnt<=37)){ output_bit(DAC_CS,0); DACCS=0; if(DACFlag==0){output_bit(DAC_PIC_CTRL,MaxV[trackk]); trackk=++trackk;}; output_bit(DAC_SCLK,DACFlag);};
if(trcnt==38){output_bit(ADC_CS,1); ADCCS=1; output_bit(DAC_CS,1); DACCS=1;};
ADCFlag=~ADCFlag;
DACFlag=~DACFlag;
trcnt=++trcnt;
delay_cycles(75); //set back to 50
if(trcnt==45){trcnt=0; trackk=0;}; //set back to 30
Edit:
Bottom of my post appears to have been lopped off.
The DAC datasheet specifies 4 leading zeros, which it reads in on the falling edge of SCLK, followed by a 12bit DAC code, i.e. 12 1's for maximum output.
The oscilloscope output seems fine, 4 leading zero's on the falling edge of SCLK, followed by the 12 bits...
Is it something obvious I'm overlooking? Have tried different DACs, so I doubt the DAC is faulty.... |
Mark
Posted: Fri Aug 12, 2005 6:13 am |
And your problems is????????????? |
Posted: Fri Aug 12, 2005 6:16 am |
I drove this chip some time ago.
The driver routine was:
void send_dac(int16 val) {
int8 mask;
int8 ctr;
mask=0x8000;
DAC_CS=0;
for (ctr=0;ctr<32;) {
if (ctr&1) {
DAC_CLK=0;
else {
DAC_CLK=1;
if (val & mask) output_bit(DAC_DAT,1);
else output_bit(DAC_DAT,0);
mask /=2;
ctr++;
DAC_CLK=1;
DAC_CS=1;
DAC_DAT, DAC_CS, and DAC_CLK were connected to and defined as the three control pins.
This was called with:
#define WAKE (0xF000)
send_dac(WAKE);
send_dac(val_to_send);
Your code looks bulkier than this (and requires sixteen numbers, instead of just a single 16bit value). However I'd suspect the 'key' difference is sending the 'WAKE' value first. If I remember correctly, the chip has the ability to go into a low power 'sleep' mode, and you must wake it up, before sending a value.
Posted: Fri Aug 12, 2005 10:44 am |
WAKE was indeed the problem
But that code looks much more flexible than mine, will take a look at it thanks  |
bwgames
Posted: Tue Aug 16, 2005 4:23 am |
Been trying to get your code above working, and can't seem to get any data output, I get the CS and SCLK out fine, but nothing on the DATA, even for WAKE.
Only modifications I've made is to replace (e.g.) DAC_CS =1 with output_bit(DAC_CS,1) etc.
I'm assuming you are doing bit masking, hence the val & mask, but what does the mask /= 2; line do? Can't seem to find any reference to /=
thanks  |
Mark
Posted: Tue Aug 16, 2005 6:02 am |
Standard C
mask = mask / 2; |
DragonPIC
Posted: Tue Aug 16, 2005 10:24 am |
Mark wrote: | Standard C
mask = mask / 2; |
Same as:
mask >>= 1;
or
mask = mask >> 1; _________________ -Matt |
