Steve Guest
Cannot find MPLAB from CCS |
Posted: Sun Jan 16, 2005 4:22 pm |
I cannot get CCS to call up MPLAB - I originally had MPLAB installed in D:/... then I installed in C:/... I have tried MPLAB6 and MPLAB7 all to no avail.
I would normally expect to be able to specifically define the path to such a file (MPLAB.EXE), if there is a option I cannot find it.
Please could someone help me here? I guess most CCS users who have to use MPLAB to use an ICD2 have overcome this.
Many thanks |
Mark
Posted: Sun Jan 16, 2005 5:48 pm |
CCS doesn't call up MPLAB. MPLAB calls up CCS. You should see 2 choices for CCS. Choose the 2nd one. If not, go to the download page and download the CCS plug in for MPLAB. |
Posted: Mon Jan 17, 2005 1:11 pm |
Mark
Thank you for your reply.
In the CCS IDE under the 'TOOLS' pull down menu is 'MPLAB' - this is supposed to start MPLAB I expect. But it has a path to C:/programfiles/mplab..... and I don't know how to poitn it to the correct location.
Cheers, Steve |
Mark
Posted: Mon Jan 17, 2005 1:13 pm |
Can't help you with that one but since you have an ICD2 why not just use MPLAB instead of the CCS IDE. |
Posted: Tue Jan 18, 2005 12:48 am |
Question was: " In the CCS IDE under the 'TOOLS' pull down menu is 'MPLAB' - this is supposed to start MPLAB I expect. But it has a path to C:/programfiles/mplab..... and I don't know how to point it to the correct location. "
Goto: Options > Debugger/Programer
In Debugger window command line > point it to the path you wish |
Posted: Tue Jan 18, 2005 5:48 pm |
Brilliant, thank you very much.
Easy when you know where to look - cheers. |
