		| View previous topic :: View next topic   |
			Eugene Onishi Guest
				| incrementing a hex number |
				 Posted: Sat Feb 22, 2003 7:32 pm     |
				I'm trying to incrment BCD number, what's the best way to do this?
___________________________
	Original Post ID: 12025 |
			Pete Smith Guest
				| Re: incrementing a hex number |
				 Posted: Sun Feb 23, 2003 3:16 am     |
				:=I'm trying to incrment BCD number, what's the best way to do this?
If you're doing a lot with BCD numbers, it would be useful to have a hex2bcd and bcd2hex routine. To increment the number, you'd just convert the number back into hex/decimal, increment it, and then convert it back again.
Here's what I use...
This one takes a BCD number, and returns the decimal equivalent, ie passing it 10 (BCD, real value=13) will return 10.
int bcd(int input)
	int temp,temp2;
	temp=(input & 0x0f);
	temp2=((input & 0xf0)/16);
	temp+=temp2*10;
	return(temp);
This one does the opposite. If you pass it 10 (decimal), it'll return 10 BCD (13).
int to_bcd(int input)
	int temp,temp2;
	temp=input \% 10;
	temp2=input/ 10;
	temp2=temp2*16;
	temp2+=temp;
	return(temp2);
HTH
Pete.
	Original Post ID: 12030 |
			R.J.Hamlett Guest
				 Posted: Sun Feb 23, 2003 4:38 am     |
A lot depends on whether you are after the smallest code space, or the fastest speed. You can either code using the 'modulus' function (\%), which gives simple code, but can be fairly slow, or just do a normal increment, and then adapt if there was a wrap over (this is the approach used in some microprocessors). The same applies when converting to/from BCD, where the use of a look up table, can be quicker, but will be bulkier than simple arithmetic.
The code below is a standard set of routines using the latter approach (including the conversions). Someone else has allready posted code using the former approach.
const unsigned int conv[16] = {
	0,10,20,30,40,50,60,70,80,90,90,90,90,90,90,90 };
#define fromBCD(x)	((x & 0xf)+conv[(x>>4)])
/* Generic routine to increment a BCD number stored in an unsigned INT */
int BCDINC(int val)
	/* routine to increment a BCD number */
	if ((val & 0xf)>8)
		/* here there must be a wrap */
		val=val+7;
		val++;
	return(val
/* BCD conversion sub */
unsigned int toBCD(unsigned int val)
	int ctr;
	for (ctr=0;ctr<10;ctr++)
		if (val == conv[ctr])
			return(ctr<<4);
		else if (val < conv[ctr]) break;
	--ctr;
	return((val-conv[ctr])+(ctr<<4));
	Original Post ID: 12032 |
