Strange Message From Debugger
tigrou
PostPosted: Wed Sep 15, 2004 9:44 am     Reply with quote
Hello
When i start the debugger with the ICDU from CCS Compiler i have the message "The ICD Unit has an old version of firmware. Use "Configure hardware" in the configuration tab to update.
I have the 3.202 Compiler.
I have the last ICDU.exe (2.12)
And i have updated the firmware of the ICDU Unit (1.29)
Have you some idea ?
ninjanick
PostPosted: Wed Sep 15, 2004 11:19 am     Reply with quote
I believe that is the latest firmware (1.29). Does it come up all the time?
Haplo
PostPosted: Wed Sep 15, 2004 5:05 pm     Reply with quote
I had this problem once. Try updating it one more time. This may make the error go away.
tigrou
PostPosted: Thu Sep 16, 2004 5:00 am     Reply with quote
to ninjanick:
yes it's the latest firmware 1.29 (13/09/04) and the warning message come up all the time i start a debug.
To haplo:
I have reloaded the new firmware three time, but the message come again !!!
Other idea's ?
PS) Thanks for ninjanick and haplo
Remo
PostPosted: Wed Sep 29, 2004 3:16 pm     Reply with quote
@all
i have the same problem,
anyone have an solution?
thx Laughing
Humberto
PostPosted: Sat Oct 09, 2004 3:44 pm     Reply with quote
My first week with the ICD-S40
I have the 3.190 Compiler.
I have the ICD Control V2.12
And i have updated the ICD-S40 firmware to V1.29
PIC16F628 @8000000Mhz
The Unit seems to work, it pass all the built in tests succesfully.
I can program and load the PIC properly and after that I get the following messge:
"Could not Start target: the target was not halted after Reset.
Check the target oscillator and MCL."
and it keept disabled all the debugging tools.
Target oscillator was checked (8Mhz stable and rail to rail).
I'm using 27K pull up resistor in MCLR and I read 4.21V in the Reset PIN. (...mmmh ?)
Any help/clue would be very well appreciated.
Thanks in advance,
Humberto
