tesla80
				| 16x1 (GDM1601) Text Lcd Driver for PIC |
				 Posted: Wed May 23, 2007 3:35 pm     |
				Hi All,
16x1_lcd_gdm1601.c
 	  | Code: | 	 		  /*
      GDM1601(16 Character, 1 Row Text LCD) Driver for PIC
            Eray Ozturk 'SpeedyX' - 14.09.2006 00:33
            Mail: erayozturk1(at)gmail.com
      lcd_init                    : init (first and once)
      lcd_command(x)              : send a command
      lcd_data(x)                 : send a character
      printf(lcd_data,"SpeedyX"); : send a word
      lcd_goto1                   : cursor goto home
      lcd_ramch                   : lcd line 2 (after 8th char)
      lcd_clrscr                  : clear screen
         PIC             LCD
         lcd_port.0      D4
         lcd_port.1      D5
         lcd_port.2      D6
         lcd_port.3      D7
         lcd_port.4      RS
         lcd_port.5      E      lcd RW pin -> ground
#define lcd_port     portb
#define t 2 // enable wait time (us)
#define lcd_putc(c)  lcd_data(c)
#define lcd_goto1    lcd_command(0b10000000)      // lcd goto home
#define lcd_ramch    lcd_command(0b11000000)      // lcd line 2
#define lcd_clrscr   lcd_command(0b00000001);bekle_ms(2)   // lcd clear
void bekle_ms(int x) {
   delay_ms(x);
void bekle_us(int y) {
   delay_us(y);
void lcd_gonder(char alt4, int1 tip) {
int ust4;
    ust4 = alt4 & 0b11110000;
    ust4 = ust4 >> 4;
    ust4 &= 0x0F;
    alt4 &= 0x0F;
    if(tip==1) ust4 |= 0b00010000;
    lcd_port=ust4;
    bekle_us(t);
    lcd_port |= 0b00100000; // enable=1
    bekle_us(t);
    lcd_port &= 0b11011111; // enable=0
    bekle_us(t);
    if(tip==1) alt4 |= 0b00010000;
    lcd_port=alt4;
    bekle_us(t);
    bekle_us(t);
    bekle_us(t);
void lcd_data(char c) { lcd_gonder(c,1); }
void lcd_command(char c) { lcd_gonder(c,0); }
void lcd_scroll_right(){lcd_command(0x1E);}
void lcd_scroll_left(){lcd_command(0x18);}
void lcd_gotox(int x) {
    int adr=0x80;
    if(x>8) adr=0xC0;
   lcd_command(adr|(x-1));
void lcd_init() {
   bekle_ms(20);
   lcd_command(0b00000010);
   lcd_command(0b00101000);
   bekle_us(50);
   lcd_command(0b00001100);
   bekle_us(50);
   lcd_clrscr;
   lcd_command(0b00000110);
   bekle_ms(10);
main.c
 	  | Code: | 	 		  #include <16F88.h>
#FUSES INTRC_IO,NOWDT,NOMCLR,NOBROWNOUT,NOLVP,NOCPD,NOWRT,NODEBUG,NOPROTECT
#use  fast_io(A)
#use  fast_io(B)
#byte porta = 5
#byte portb = 6
#include <16x1_lcd_gdm1601.c>
   setup_oscillator(OSC_4MHZ);
   set_tris_a(0);
   set_tris_b(0);
   porta=0; portb=0;
   lcd_init();
   printf(lcd_data,"SpeedyX GDM1601");
   //printf(lcd_data,"SpeedyX "); lcd_ramch; printf(lcd_data,"GDM1601"); // for lcd-s with 8-8 ram structures
   for(;;); // loop forever
