CCS Debugger with Microchip ICD2
vleiswal
PostPosted: Sun Aug 08, 2004 10:58 am     Reply with quote
I need help in using a Microchip ICD 2 (on USB) from the CCS compiler front end.
What s/w do I need?
It keeps telling me the h/w NOT FOUND.
Thanx
PostPosted: Sun Aug 08, 2004 12:59 pm     Reply with quote
If you have the Microchip ICD2, you should use MPLAB software.
The latest version is v6.60. Download it from the Microchip website.
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en019469&part=SW007002
vleiswal
PostPosted: Sun Aug 08, 2004 2:41 pm     Reply with quote
Thanks...... it is working fine in MPLab, however, would like to get it working in CCS also.
Is it possible?
Mark
PostPosted: Sun Aug 08, 2004 10:25 pm     Reply with quote
It is possible to install CCS compiler to work with MPLAB. Get the plugin from CCS's site under their downloads.
vleiswal
Microchip ICD2
PostPosted: Mon Aug 09, 2004 1:38 am     Reply with quote
MPLab and CCS working fine!!! Driver loaded and using debugger in MPLab
However, would like to use CCS debugger with MPLab ICD 2. Is this possible?
Thanx
Mark
PostPosted: Mon Aug 09, 2004 5:56 am     Reply with quote
From CCS's website
CCS provides a high level debugger for the Microchip PICŪ line of microcontrollers. This debugger is included with PCW, CCS's C Compiler with Windows IDE, and requires an ICD unit (Microchip MPLABŪ-ICD1, CCS ICD-S40 or CCS ICD-U40) connected to a flash PIC series microcrontroller that is capable of debugging (such as the PIC16F87x or PIC18Fxx2). Future support will include other emulator and debugging hardware and the dsPICŪ line of microcontrollers.
No ICD-2 at this time
vleiswal
PostPosted: Mon Aug 09, 2004 1:46 pm     Reply with quote
Thanxs Mark!!
Perhaps CCS can let us know when their debugger will work with Microchip ICD2....
Wink
pic my brain
PostPosted: Thu Sep 30, 2004 2:43 pm     Reply with quote
I also would like to know when they add support for the ICD-2.
I really don't like the MPLAB environment.
I do like the CCS environment but it's useless without support for the ICD-2.
It would also be nice if CCS would document some of the canned functions such as 'SETUP_POWER_PWM()' for the 18F2331.
I can't seem to get it to work. Keeps giving a 'comma expected' error!
PostPosted: Mon Oct 04, 2004 11:11 am     Reply with quote
See this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=20348&highlight=setuppowerpwm
Mark
PostPosted: Wed Oct 06, 2004 7:40 am     Reply with quote
Also always check the help file in the software directory. It is the manual and is usually pretty up to date.
smashHIT
View user's profile Send private message ICQ Number
PostPosted: Sat Dec 11, 2004 12:49 pm     Reply with quote
If a get my self an ICD2 I won't be able to use it within CCS IDE, right? But will I be able to use it within MPLAB with the CCS plugin? I mean, so I can debug CCS c-code in MPLAB.
