ICD Work for Debugging but not normal burning
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
kory@avatar.com
PostPosted: Mon May 24, 2004 5:27 pm     Reply with quote
My ICD works incredibly well for source level debugging. I absolutely love it. But when I try to flash the PIC with a normal program with debugging turned off, it (my application) won't run. I can flash using the ICD2 and the exact same .HEX file using MPLAB and it works right.
Any clues?
Thanks,
Kory
Darren Rook
PostPosted: Tue May 25, 2004 7:52 am     Reply with quote
What do you mean won't run?
Are you using PCW or the stand-alone ICD program to burn your chip?
kory@avatar.com
ICD Work for Debuging but not notmal burning
PostPosted: Wed May 26, 2004 11:57 am     Reply with quote
By "won't run", I mean it doesn't execute my code, as far as I can tell. The PIC is executing something else, but not my code. Maybe its not executing anything -- I can't tell. It there is a way to tell, I'd like to know as I am new to the PIC chips.
I've tried programming both ways: from inside PCW or using ICD stand alone. Again, the same hex time programmed using the ICD2 & MAPLABS works.
Thanks,
Kory
[/quote]
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
