LCD driver
RatFink
LCD driver
PostPosted: Sat May 15, 2004 12:07 pm     Reply with quote
I'm posting this here because I spent a long time looking for a driver that worked for me, I finally found this hidden in the back pages of the forum, it worked right off the bat for me. and was originally posted by a member named chava in this thread;
http://www.ccsinfo.com/forum/viewtopic.php?t=17323&highlight=picdem+2
Since I'm a beginner at this and had already spent a week trying to get my LCD to work, finding code that work for me very easily seemed like something others would find helpfull.
BTW, I'm using a PIC16F877A w/ a CrystalFontz LCD w/ aHD44780 compatible controller.
////////////////////   LCD   //////////////////////////////
// As defined in the following structure the pin connection is as follows:
//     A1  enable
//     A2  rw
//     A3  rs
//     D0  D4
//     D1  D5
//     D2  D6
//     D3  D7
//   LCD pins D0-D3 are not used and PIC D3 is not used.
#if defined(__PCH__)
   #byte lcd = 0xF83      // This puts the entire structure
#else
   #byte lcd = 8          // on to port D (at address 8)
#define lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40    // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
                            // These bytes need to be sent to the LCD
                            // to start it up.
                     // for 2 lines lcd: {0x0a,0xc,1,6}
                     // for 5x10 lcd:   {0x06,0xc,1,6}
                     // for 5x7 lcd:      {0x20,0xc,1,6}
                             // The following are used for setting
                             // the I/O port direction register.
//***** lcd command port  *******************************************************************
struct lcd_command{
   char none:1;
   char enable:1;
   char read_write:1;//rw
   char data_command:1;//rs
struct lcd_command lcd_command_port;
#locate lcd_command_port=5
struct lcd_data{
   char data:4;
struct lcd_data lcd_data_port;
#locate lcd_data_port=8
//************  "COMMAND / DATA definition  ************************************************************
#define COMMAND0 0
#define DATA1 1
//************  "READ / WRITE definition  ************************************************************
#define WRITE0 0   //LCD <- MPU
#define READ1 1  //LCD -> MPU
//************  "E_UP / E_DOWN definition  ************************************************************
#define E_DOWN 0
#define E_UP 1
//**********eeprom or flash******************************************************************************
#define EEPROM0 0   ;eeprom - not the program  memory
#define FLASH1 1   ;program memory
//*********  set tris d  *********************************************************************
#define set_tris_lcd_read(){\
   set_tris_a(TRISA & 0xf1/*0b11110001*/);\
   set_tris_d(TRISD | 0x0f/*0b00001111*/);\
#define set_tris_lcd_write(){\
   set_tris_d(TRISD & 0xf0/*0b11110000*/);\
//***********   clear LCD  ************************************
#define clear_lcd   lcd_send_byte(0x1,COMMAND0);//clear lcd display
char lcd_read_byte(void){
      char low,high;
      set_tris_lcd_read();
      lcd_command_port.read_write = READ1;
      delay_cycles(1);
      lcd_command_port.enable = E_UP;
      delay_cycles(1);
      high = lcd_data_port.data & 0x0f;
      lcd_command_port.enable = E_DOWN;
      delay_cycles(1);
      delay_us(1);
      low = lcd_data_port.data & 0x0f;
      set_tris_lcd_write();
      return( (high << 4) | low);
void lcd_write_nibble(char temp_wr){
//Purpose:
      lcd_data_port.data = temp_wr;
      delay_cycles(1);
      lcd_command_port.enable = 1;
      delay_us(2);
      lcd_command_port.enable = 0;
void lcd_send_byte(char data , char data_or_command ) {
      lcd_command_port.data_command = COMMAND0;
      while ( bit_test(lcd_read_byte(),7) ) ;
      lcd_command_port.data_command = data_or_command;
      delay_cycles(1);
      lcd_command_port.read_write = WRITE0;
      delay_cycles(1);
      lcd_write_nibble(data >> 4);
      lcd_write_nibble(data & 0xf);
void lcd_gotoxy( char location, char line) {//location 0...
   char address;
   if(line!=1)
     address=40;//was80
     address=0;
   address+=location;
   lcd_send_byte(0x80|address,COMMAND0);
//********** -  1 - **************************************************
void lcd_init(void){
//Purpose: initiate the lcd
   //turnning PORTA0=analog, PORTA1-7=digital
   ADCON1=0x0e;
   //turnning command pin of lcd to output
   //delay 15msec
   delay_ms(15);
   lcd_command_port.enable=0;
   lcd_command_port.data_command=0;
   lcd_command_port.read_write=0;
   lcd_data_port.data=0;
   delay_ms(2);
   lcd_write_nibble(0x03);//was 30  ddram address: 1:1bit,line:1bit,address:4bit
   delay_ms(10);//more then 4.1msec
   delay_us(150);//more then 100usec
   delay_us(100);
   lcd_write_nibble(0x02);//was 20
   while(bit_test(lcd_read_byte(),7));
   lcd_send_byte(0x28,COMMAND0);//was 0x28 portd[3:0]=x2 then portd[3:0]=x8
                     //  4 bit low nibble, ddram address=0 first line
   lcd_send_byte(0x0c,COMMAND0);//disp on
   clear_lcd;
   lcd_send_byte(0x6,COMMAND0);//entry inc
   lcd_gotoxy(1,1);
void lcd_putc( char c) {//this function works good
   switch (c) {
     case '\f'   : lcd_send_byte(1,COMMAND0);   delay_ms(2);   break;   //Clear display
     case '\n'   : lcd_gotoxy(1,2);                        break;   //Go to start of second line
     case '\b'   : lcd_send_byte(0x10,COMMAND0);               break;   //Move back one position
     default     : lcd_send_byte(c,DATA1);                  break;   //send the actual character
char lcd_getc( char location, char line) {
      char value;
    lcd_gotoxy(location,line);
    while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
    lcd_command_port.data_command=1;
    value = lcd_read_byte();
    return(value);
      return 1;
void lcd_put_string(char *string){
//put string, starting  from the curren cursor position
//assume that string not excides from lcd displayed RAM
   char index=0;
   while(string[index]!=0){
      lcd_putc(string[index++]);
void lcd_put_string_xy(char *string, char pos, char line){
   lcd_gotoxy(pos,line);
   lcd_put_string(string);
void stan_char(long *ptr,char line,char eeprom_or_flash){
//Purpose: write 16 chars, given in ptr location(eeprom or flash)
//to line of lcd, from the begining of the line
   char c,i;
   lcd_gotoxy(1,line);
/*OR:   switch(line==1) {
      case 1:lcd_send_byte(0x80,COMMAND);   //initiate lcd to write to line 1
      case 2:lcd_send_byte(0xc0,COMMAND);   //initiate lcd to write to line 2
   for (i=0;i<16;i++){
      if (eeprom_or_flash)
         c=read_program_eeprom(ptr+1);
         c=read_eeprom((char)ptr+1);
      lcd_putc(c);ptr++;
LCD_INIT
MOVLW DISP_ON ; Display On, Cursor On               = 0x0C
CALL SEND_CMD ; Send This command to the Display Module
MOVLW CLR_DISP ; Clear the Display                  =0x01
MOVLW ENTRY_INC ; Set Entry Mode Inc., No shift         =0x06
SEND_CHAR
   MOVWF CHAR ; Character to be sent is in W
   CALL BUSY_CHECK ; Wait for LCD to be ready
   SWAPF CHAR, W
   ANDLW 0x0F ; Get upper nibble
   MOVWF LCD_DATA ; Send data to LCD
   BCF LCD_CNTL, RW ; Set LCD to read
   BSF LCD_CNTL, RS ; Set LCD to data mode
   BSF LCD_CNTL, E ; toggle E for LCD
   BCF LCD_CNTL, E
   MOVF CHAR, W
   ANDLW 0x0F ; Get lower nibble
   BCF LCD_CNTL, E*/
SEND_CMD
   MOVF CHAR,w
   ANDLW 0xF0 ; Get upper nibble
   BCF LCD_CNTL,RW ; Set LCD to read
   BCF LCD_CNTL,RS ; Set LCD to command mode
   BSF LCD_CNTL,E ; toggle E for LCD
   BCF LCD_CNTL,E
   SWAPF CHAR,w
   ANDLW 0xF0 ; Get lower nibble
   BCF LCD_CNTL,E
BUSY_CHECK
   BSF STATUS, RP0 ; Select Register Bank1
   MOVLW 0xFF ; Set Port_D for input
   MOVWF LCD_DATA_TRIS
   BCF STATUS, RP0 ; Select Register Bank0
   BCF LCD_CNTL, RS ; Set LCD for Command mode
   BSF LCD_CNTL, RW ; Setup to read busy flag
   BSF LCD_CNTL, E ; Set E high
   BCF LCD_CNTL, E ; Set E low
   MOVF LCD_DATA, W ; Read upper nibble busy flag, DDRam address
   ANDLW 0xF0 ; Mask out lower nibble
   MOVWF TEMP
   BSF LCD_CNTL, E ; Toggle E to get lower nibble
   BCF LCD_CNTL, E
   SWAPF LCD_DATA, w ; Read lower nibble busy flag, DDRam address
   ANDLW 0x0F ; Mask out upper nibble
   IORWF TEMP ; Combine nibbles
   BTFSC TEMP, 7 ; Check busy flag, high = busy
   GOTO BUSY_CHECK ; If busy, check again
   BCF LCD_CNTL, RW
   MOVLW 0x0F
   MOVWF LCD_DATA_TRIS ; Set Port_D for output
