Timers to keep track of time and time events
Neutone
PostPosted: Mon May 10, 2004 9:38 am     Reply with quote
In the following example it is assumed that the Clock_Service function is called much more often than once per mS. It is also assumed that other functions will be executed only when their flags are set. The timer value is never set it is free running. The timer is setup as follows
with a xtl @ 4Mhz the clock will increment ever 1uS
For a 1mS interupt the clock must increment 1000 times
pre-scaler is set to 4 and the count is set to 250
250 * 4 = 1000
The post-scaler is set to 1
If the xtl was 8Mhz the post-scaler would need to be 2
If the xtl was 20Mhz the post-scaler would need to be 5
int1  Clock_Been_Initialized=0;
Int16 Miliseconds;
Int16 Seconds;
int1  miliSecond_Tick=0;
int1  Second_Tick=0;
int1  Read_Temperature=0;
int1  Read_ADC_Now=0;
// Global Real Time Clock Interupt
#int_TIMER2
void TIMER2_isr()
{  Miliseconds++;
   miliSecond_Tick=1;
   if(Miliseconds>999)
   {  Miliseconds=0;
      Seconds++;
      Second_Tick=1;
*    Service Clock                                         *
#inline
void Clock_Service(void)
{  if(!Clock_Been_Initialized)
   {  setup_timer_2(T2_DIV_BY_4,249,1);                     // Set 1mS period on a 4Mhz xtl
      Seconds=0;
      Clock_Been_Initialized=1;
   if(Second_Tick)
   {  Second_Tick=0;
      Read_Temperature=1;                                   // This flag will trigger another event to occur
   if(miliSecond_Tick)
   {  miliSecond_Tick=0;
      Read_ADC_Now=1;                                       // This flag will trigger another event to occur
