runtime
Floating Point numbers not supported??? |
Posted: Wed Jan 07, 2004 10:32 am |
I want to do a simple math division and get a result in decimal format, I'm reading a voltage with read_adc() which returns an integer, now I want to divide that number by 2 and get the result with 1 digit after the decimal point, if I try the following I get 'Floating point numbers not supported' from the compiler...
int TRead;
float CValue;
in main:
TRead = read_adc();
CValue = TRead/2.0;
fprintf(COM,"CValue: %3.1f \r\n",CValue);
any ideas?
Thank you in advance |
Re: Floating Point numbers not supported??? |
Posted: Wed Jan 07, 2004 10:46 am |
runtime wrote: | Hello,
int TRead;
float CValue;
in main:
TRead = read_adc();
CValue = TRead/2.0;
any ideas?
Which compiler?.
What you show should work (though it is sometimes worth being a bit 'butch' with the compiler, and forcing the type conversion, with code like):
CValue = (float)TRead/2.0;
However your error message, sounds like you might have one of the demo versions that did not have 'float' support.
Posted: Wed Jan 07, 2004 10:48 am |
Ttelmah wrote: | runtime wrote: | Hello,
int TRead;
float CValue;
in main:
TRead = read_adc();
CValue = TRead/2.0;
any ideas?
Which compiler?.
Worth perhaps adding, that you can get your required result, possibly with less code, and quicker, without using a float, with:
fprintf(COM,"CValue: %2u.%1u \r\n",Tread/2,Tread\2);
KerryW Guest
Posted: Wed Jan 07, 2004 4:11 pm |
or you could do it like this:
int TRead;
in main:
TRead = read_adc();
fprintf(COM,"CValue: %u.%c \r\n",TRead>>2, (TRead&1)?'5':'0');
Which breaks down like this:
%u.%c \r\n" // print an unsigned float, a decimal point, a character, and a newe line
,TRead>>2 // print TRead divided by 2 (right shifted once)
, (TRead&1)?'5':'0'); // if TRead is odd, print '5', if it's even, print '0'
The last digit can only be 0 or 5 anyway. This method doesn't use any multiplication or divide routines. It will be very short and very quick. |
Alan Murray Guest
Posted: Fri Jan 30, 2004 8:18 am |
The problem is that when you divide 2 decimal numbers the compiler stores the result as a decimal thereby throwing away the remainder.
For dividing by powers of 2 shifting left works as suggested above.
However a much simpler option is to cast both divisor and dividend as floats before doing the division - this will yield a floating point result. e.g.
int adcReading;
float tempADC, result;
tempADC = (float)adcReading;
result = tempADC/2.0;
This will handle all integers - not just powers of 2. ![Smile](images/smiles/icon_smile.gif) |
