Resolution on tmr0
pitufos
Resolution on tmr0
PostPosted: Tue Jan 06, 2004 10:19 am     Reply with quote
Hi
I need your comments on this code...
Well... I need count time spend of complete signal. On this code i can only resolution in ms... I need resolution in us...but much better precision...
#include <16F84A.h>
#fuses XT, NOWDT, PUT
byte ms;
#int_rtcc
clock_isr()
ms++;
void discarrega()
output_B(0x52);
if (input(PIN_A2) == 0 )
output_high(PIN_A3);
output_low(PIN_A3);
output_B(ms);
output_low(PIN_A3);
set_timer0(231);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_4);
enable_interrupts(GLOBAL | INT_RTCC);
//setup_counters(RTCC_INTERNAL, RTCC_DIV_4 | RTCC_8_BIT);
//enable_interrupts(GLOBAL);
//enable_interrupts(INT_RTCC);
set_tris_B(0);
while (true)
if (!input(PIN_A0))
while (!input(PIN_A0));
set_timer0(231);
ms = 0;
while (input(PIN_A0));
discarrega();
thanks...
Neutone
Re: Resolution on tmr0
PostPosted: Tue Jan 06, 2004 11:35 am     Reply with quote
output_low(PIN_A3);
This will not allow time for the pin to change state you should insert a pause.
What is you goal for the code to acomplish.
