Servo controller
johnh
Servo controller
PostPosted: Sun Jan 04, 2004 6:12 pm     Reply with quote
Hello all,
I want to control 3 groups of servo motors, essentially i can just assume as far as the PIC is concerned it is just 3 servo motors..
I am completely new to this and two days ago i didn't have a clue (some of you may still think that after reading what i have written below!! Smile )
I have had some good help from Adrian (hillcraft), thanks for that, i think i am understanding things a bit better, but i still need some pointers.
What i need to do is look for a byte of data coming from a PC between 0 and FF
if the byte is between 0x00 and 0x0F then deactivate all motors
if the byte is between 0x10 and 0x5F then servo group 1 activated and the motor needs to be moved to a position according to the hex value
with - 0x10 = full right ~ 1ms pulse
- 0x36 = centered ~ 1.5ms pulse
and - 0x5F = full left ~2ms pulse
if a value outside of this range was received then the motor would continue to hold the last commanded position unless the value received was 0x00 (deactivate all servos)
a repeat of this for motor group 2 between 0x60 - 0xAF
and a repeat for motor group 3 between 0xB0 and 0xFF
Questions now!
1. is this do-able?
2. how do i test the incoming byte to see which servo group i want to control? If the byte is for group 1 then could i use the 'test' result to go to a function that then did the position decoding?
3. Servo motors need a position pulse every 20ms, hence can i just call a function relating to servo group 1 every 20ms and update position data, then call servo group 2, update that position then servo group 3..etc
Cheers
John
There are 10 kinds of people who understand binary, those who do and those who don't
Doug
PostPosted: Tue Jan 06, 2004 10:19 am     Reply with quote
1. is this do-able?
Of course it is.
This can be accomplished by just a couple IF statements and then calls to functions that do something with the data.
if (some_byte <= 0x0F)
                   deactivate_motors(some_byte);
if (some_byte <= 0x10 && some_byte >= 0x5F)
            move_group_1(some_byte);
if (some_byte <= 0x60 && some_byte >= 0xAF)
           move_group_2(some_byte);
etc......
You could do something like:
move_group_1(int data_byte) {
int x;
x=12;
 // you know the byte will be between 0x10 and 0x5F
data_byte = data_byte - 0x10;
// data_byte will now be between 0 and 4F
output_high(PIN_CONNECTED_TO_GROUP_1);
delay_ms(1); // the minimum on time for servo
// this loop will delay for a number of microseconds in data_byte 12 times
// which will give a delay between approx. 0 to 1 ms
do {
        delay_us(data_byte);
     } while(--x);
// now the output pulse will be on for 1 - 2 ms
output_low(PIN_CONNECTED_TO_GROUP_1);
Make a routine for each group and call them repeatedly. Don't forget to store the value for each group separetly. Put a delay of 6 ms (20/3) between each call, that will give you 18ms between each pulse.
Hope this helped.
johnh
PostPosted: Tue Jan 06, 2004 10:36 am     Reply with quote
Cheers Doug,
I will have a look at that... Seems easy when someone explains how to do it. I wouldn't have known where to start!!
One question. Where does the value 12 in the last bit of code come from? and what does it do?
Thanks again
John
johnh
Ahh!
PostPosted: Tue Jan 06, 2004 10:41 am     Reply with quote
Just figured it out! It is 0x4F times 12 gives 960. So the value in data_byte multiplied by 12 gives the on time for the servo (plus the 1ms delay)
Ta..
Doug
PostPosted: Tue Jan 06, 2004 10:58 am     Reply with quote
Oops! Made a mistake in IF statments above.
Should read:
if (some_byte >= 0x10 && some_byte <= 0x5F)
Had the < and > the wrong way! Meaning if some_byte is greater than or equal to 0x10 and less than or equal to 0x5F.
Sorry!
