how to measure short distance <3mm
Pete
PostPosted: Wed Dec 24, 2003 12:47 pm     Reply with quote
hi,
Can someone help me, how to measure a short distance (less than 3mm) ? hope someone knows where to start.
Pete
mkent
PostPosted: Wed Dec 24, 2003 5:57 pm     Reply with quote
There are several methods. Do a search on LVDT (linear voltage differencial transformer) also try www.keyence.com They make optical devices. Bring a fat wallet. Merry Christmas and Great 2004 to all. Mick
position sensing
PostPosted: Tue Dec 30, 2003 1:29 pm     Reply with quote
We make an educational object tracking system, mostly for teaching physics. But, it's based on video input so you can "zoom in" to measure small distances. You could look at our Website www.AlbertisWindow.com, or if you want to tell me more about your application I could give you a more specific reply.
PostPosted: Tue Dec 30, 2003 2:20 pm     Reply with quote
Try using a ruler .... or be more specific about your application ;-)
Mark
PostPosted: Tue Dec 30, 2003 2:56 pm     Reply with quote
A ruler wouldn't work! You would need a set of calipers.
SherpaDoug
PostPosted: Tue Dec 30, 2003 3:49 pm     Reply with quote
You might be able to use capacitance. It can be cheap and rugged, though it is usually used at <1mm. It depends on your budget and accuracy requirements.
Tell us more!
Hans Wedemeyer
IR
PostPosted: Wed Dec 31, 2003 10:55 am     Reply with quote
Look a the data sheet for the IR proximity detector I used in this design.
http://hans-w.com/RPM.gif
It is good for at least 3mm
If you scale the DC output with an op-amp then use the 10 bit ADC in the pic the resolution can be very good.
I also used the same sensor for a mouse button...
http://hans-w.com/Mouse_6.jpg
Happy new year...
Neutone
Re: how to measure short distance <3mm
PostPosted: Wed Dec 31, 2003 4:00 pm     Reply with quote
Pete wrote:
hi,
Pete
You can get analog hall effect sensors from Allegro that can be used to derive distance based on the change in flux density from a distance change in a magnets position. They might even have some application notes.
Measuring Linear Displacement
PostPosted: Mon Jan 05, 2004 2:48 am     Reply with quote
Use a linear pot like a slider volume control from a radio (these are usually log taper, though.) 3 mm is really short. You may have resolution problems. Pots wear out and get noisy, too.
