10 bit DAC I2C
kreuzkopf
10 bit DAC I2C
PostPosted: Fri Dec 05, 2003 7:36 am     Reply with quote
hi everyone!
i have a pic16f73 and a tc1321 (10bit DAC)
i'm not sure how i have to send my data to the dac.
this is my test-program which doesn't work Sad
i hope someone can help me Rolling Eyes
#include <16f73.h>
#fuses  HS,NOWDT,NOPROTECT
#use    delay(clock=1000000)
#use    i2c(master,SCL=PIN_C3,SDA=PIN_C4)
main()
i2c_start();
i2c_write(0x90); //address
i2c_write(0x00); //command
i2c_write(0xff); //data
i2c_stop();
[/url]
PostPosted: Fri Dec 05, 2003 1:27 pm     Reply with quote
The delay statement below is set for 1 MHz.
I suspect that it should really be 10 MHz.
#include <16f73.h>
Also:
1. Do you have pullup resistors on SCL and SDA ?
You could use 4.7K resistors.
2. Do you have a Vref voltage applied to the Vref pin of the TC1321 ?
If your Vdd is +5v, then the maximum Vref voltage can be 3.8v.
You can create the Vref voltage by using two resistors to make
a voltage divider. To start, you could just grab a 2.2K and a 3.3K
resistor. This would give you a Vref of 3.0 volts. The output
voltage swing of the TC1321 would then be from 0 to 3.0 volts.
You'll notice that Microchip shows an additional amplifier following
the TC1321 in their application circuit. That's to get the output
voltage swing back up to where you'd really like it to be, since
the TC1321 itself can't do a rail-to-rail output.
3. In your code below, you're continuously writing to the DAC.
You don't really need to do that.
i2c_start();
i2c_stop();
It should be sufficient to just write to it once.
main()
i2c_start();
i2c_stop();
iso9001
PostPosted: Fri Dec 05, 2003 2:12 pm     Reply with quote
Personally, I dont really understand how your even working with a TC1320.... its tiny as hell... I got some samples in and hit myself in the head for not REALLY reading over the datasheet (well, they look big enough in the pic Very Happy )
If anyone is interested, Maxim makes some I2C, RailtoRail, 8/10/12 bit DACs, but in DIP sizes (8/14/16/20)...
I was wondering though, when you send command to the DAC, do you need to recieve its ACK or it that optional... Also, how long does that command last ? ie: is it momentary or does it last untill you change it or turn it off?
PostPosted: Mon Dec 08, 2003 3:39 am     Reply with quote
i have 2k2 pullups and 3v ref voltage
i've viewed scl and sda on the oscilloscope
the signal look ok
is the code really ok? i havn't used the i2c befor Confused
